Canon Pixma MX340 printer. How to clear Error 5200?
PaulR
I have a Canon Pixma MX340 multi-function printer. How do I clear Error 5200? The message said to turn the printer off and then on, and if that did not clear the error to consult the user's manual. On/off did not clear the error, and the online user's manual does not have Error 5200.
77 REPLIES 77
Thank you so much this worked, I have been trying to fix this for three days, and decided to look on line for the answer which sent me to you. 100 stars for you. THIS WORKS IF DONE RIGHT. again God Bless you.
Thankyou soooooo much.
I had many things to print and the printer just buckled.
Thankyou for all these forums..it just worked..
it worked. thanks
thank you cx2browns , it worked. Smiley Wink
Thank you!!!
Thank you!!!   Worked great!!!
I'm not sure, but, it seemed to be a problem with the paper feeder?
Oh my gosh! You are a life saver! I tried everything and I thought there was a problem with the hardware, but this fixed it! Thank you so so so much!! Canon, get this person an award or something!!!
Perfect. It worked! Thank you. you have no idea what kind of a life saver you are!
It Worked thank you! from a frustrated Mom....
I have a Canon MX350 and these steps also worked for the 5200 error code on it!
Avatar
