Canon Pixima ip6600D 6500 error code
Bero
I have Canon printer - Pixima ip6600D and first I had a problem with printer head. Suddenly one day I got messge "Printer head is not installed". After I put new print head I got message "6500 Error code". How can I fix this problem? Thank you
6 REPLIES 6
hc
Same problem..still researching.
PeterHL
I also have the same printer and same problem. Please share the solution if you find one.
Peter
Hi PeterHL,
It is recommended that you contact live technical support . There is NO charge for this call. Real time feedback of a live technical support call would be very beneficial in this case.
Please dial 1-866-261-9362, Monday - Friday 10:00 a.m. - 10:00 p.m. ET (excluding holidays). A Canon technical support representative will be able to resolve this issue faster.
That appears to be a number in the US. I am in South Africa. Is there an equivalent number in SA or is there an email address I could use?
Hi, PeterHL!
Our friends at Canon South Africa can help you.  You'll find them at http://www.canon.co.za
Thanks for choosing Canon!
Many thanks Danny, I'll try them again.
