01-23-2020 01:05 PM
I recently installed Windows 10 Pro 64-bit on my Dell XPS 8900 desktop PC. When I tried to scan something I found that the scanner was not installed!
Does the scanning function work with Windows 10?
Any suggestions for what I need to do next?
Thank you in advance.
01-23-2020 02:18 PM
01-24-2020 02:45 PM
Hi WebPixie,
Please disconnect the USB cable from the back of your PIXMA MX472 and then follow these steps:
1. Press the Windows key on the keyboard and the letter R and then let both go.
2. In the Run window, please type CONTROL PANEL and click OK.
3. In Control Panel, please click on View devices and printers (or Devices and printers, depending on the view).
4. Right click the Canon MX470 series Fax and left click on Remove device to remove that icon from this window.
5. Once gone, please click on Control Panel in the upper left corner (or the Back button).
6. In Control Panel, click on Uninstall a program (or Programs and features, depending on the view).
7. In the list of programs, if you see Canon MX470 series MP Drivers, click on it one time and then click Uninstall at the top.
8. Follow the on screen prompts to uninstall.
Once gone, please restart the computer.
When the computer restarts, we will reinstall:
1. Use the following link to access the downloads for your PIXMA MX472:
2. Click the Select button next to "MX470 series MP Drivers Ver.1.02 (Windows)".
3. Click the Download button.
4. Once the download is complete, please open your downloads folder and double click "mp68-win-mx470-1_02-ea33_3.exe" to begin the installation process.
5. Follow the prompts to install the drivers, reconnecting the USB cable when prompted by the installer.
Once installed, to scan, please click on the Windows Start button in the lower left corner and then the Canon Utilities folder. In the Canon Utilities folder, click on the IJ Scan Utility. You can use this application to scan with your PIXMA MX472.
For more information regarding the IJ Scan Utility, please use this link:
https://ugp01.c-ij.com/ij/webmanual/ScanUtility/W/MX470%20series/1.1/EN/SU/Top.html
