Canon Mx922 not printing - solution found!
g35jackson
Every time I would try to print, I would get an error message in the printer queue window.  I'm not sure if this happened because I tried to connect to other printers at different locations, but somehow my communication between the devices was manipulated.  First, of course, I checked wifi connection, on both printer and laptop but could not find anything wrong.  I've updated the Driver, no luck. I've restarted to Printer Spooler Service, no change.  After hours of searching online, I finally found a solution. Hope this will help someone else out there who may have a similar problem, try the following:
https://ij.manual.canon/ij/webmanual/NetworkTool/W/3.2/EN/NWT/NWT_Appendix0600.html
0 REPLIES 0
