03-10-2022 03:06 PM
I wanted desperately to print on a No 6 3/4 envelope (6.5"x 3.5'), even though clearly the Canon MX922 sheet feeder didn't accommodate them, as they are too small. But I tried anyway. It fed one, then the next jammed. One was retrievable, but the other, even following the error guidance, remained invisibly up inside the paper path. The Canon error guidance was good, but it couldn't outwit my stupidity feeding a too-small item.
I read and watched everything. No luck.
However, I finally realized I might be able to gently poke it through. I took a No. 10 Envelope (4 1/8 "x 9 1/2"), sealed it, let it dry. I then:
