Canon MG5751 - B203 Error Code and Priting Issue
Dan33
Hello
I have the dreded B203 Error Code..
When i turn on the printer i get the Copy, Scan, folders...Then within a few seconds  i get the B203 Error Code...So i turn off  printer and then  open the part where the inks show and turn the printer on. Then i drop/close and the printer re-rights itself .
I then place paper into the printer tray to copy a letter... I open wordpad, click on file, click print . It goes through the motions and makes the noice, but the paper just stays where it is. Then the dreded B203 Error Code appears once again. All inks are full so i'm not sure if this is a issue.
Any info / fix would be most appreciated.
Thanks
2 REPLIES 2
This error / issue is documented in the product manual  Unfortunately, the solution is service or replacement.
Canon : PIXMA Manuals : MG5700 series : B203
Thanks shadowsports for the reply... I had come across that info...But what would the repair entail?.. Something easy or something mayor to put right... Being out of warranty i was hoping someone could point me in the right direction and i could fix it myself. Thanks again,
