07-20-2013 05:31 PM
My Canon mg5220 will not print black. I have refillable cartridges in it. I took the print head out and cleaned it. The cartridges have plenty of ink. Please help!
07-22-2013 09:57 PM
Hi TeachSMH,
physically cleaning will only get the outside of the print head clean. Since the nozzles are so tony they can only be cleaned by going through the cleaning process in the Maintenance menu of the printer. Please try the following steps 2-3 times conescutively for the best results:
- If the Inner Cover is open, close it.
4. Clean the Print Head deeply.
(1) Select Setupon the HOME screen.
The Setup menu screen will appear.(2) Select Maintenance, and press the OK button.
The Maintenance screen will appear.(3) Select Deep cleaning, and press the OK button.The confirmation screen will appear.(4) Select Yes, and press the OK button.The machine starts cleaning the Print Head deeply.Do not perform any other operations until the machine completes the deep cleaning of the Print Head. This takes about 2 minutes 30 seconds.The pattern print confirmation screen will appear.(5) Select Yes, and press the OK button.The nozzle check pattern will be printed.(6) When the completion message appears, press the OK button.The screen will return to the Maintenance screen.
If the issue persists, I recommend using the Contact Us link to get in touch with our support staff who can provide service options.
07-22-2013 09:57 PM
Hi TeachSMH,
07-22-2013 10:10 PM
05-30-2014 09:29 PM
My 5320 wilol not print from the large black cartrige. I have tried three different cartriges and have replaced the print head with a new one. I have gone through 3 regular cleanings and 3 deep cleanings. Still nothing at all. Is there anything else that can be done.
07-10-2014 08:06 AM
Hi htobin,
Since performing the cleanings and deep cleanings, as well as replacing the print head did not resolve the issue, the printer will require servicing. Please call or email us at one of the methods on the Contact Us page to obtain your servicing options.
06-23-2016 10:44 PM
I understand this uses a lot of ink. Can I just clean the black head or do I have to do all of then even though only the black is plugged?
06-25-2016 11:47 AM
Hello.
The cleaning process will use all of the colors. There is no way to isolate a particular color for this process.
If you continue to have difficulties, find more help at Contact Us.
06-25-2016 12:32 PM
The instructions say to selected the "accept as solution" button, but I don't see one, so please accept my response as such.
Thanks.
01-18-2017 02:14 PM
Problem fixed immediately. Thank you!
06-18-2017 12:27 PM - edited 06-18-2017 12:28 PM
Mine has just started to do the same thing. I already have a filthy hate for this particular unit, so having to search for this "solution" is truly a nightmare. Smashing this piece of garbage onto the concrete parking lot in front of me would be more fulfilling at this point than actually "fixing" it, but I'll continue on.
