08-14-2023 09:15 AM
I want to print on standard pre-printed bank checks but the MG2522 adjustable paper guide does not move far enough to the right to properly guide the checks (2.75 inch wide). Because of the gap, the checks turn slightly while feeding. Is there a workaround? Can I safely insert a spacer next to the paper guide to close the gap? Does Canon make a spacer? Please advise.
08-16-2023 01:50 PM
Bank checks are not a supported media type with this model printer. Canon does not make a spacer that would fit next to the paper guides.
08-16-2023 01:50 PM
08-22-2023 02:19 PM
Thanks ArthurJ for responding. Hopefully, future Canon printers will accommodate the ability to print on bank checks.
