Canon MG2120 Error Code: 5,156,61
Travis
Hi
I have a Canon MG2120.
I have tried to install the software and driver CD many times with everything installing correctly except for the scanner driver.
I keep getting a error message saying "Code:5,156,61 Cannot scan for these reasons: -Scanner is turned off.-USB cable is disconnected"
So I uninstalled all drivers and software, went to the Canon driver and software download page and downloaded all teh updagted drivers and software and rebooted my laptop.
After rebooting, I opened the MP Navigator and tried to scan a photo and got the same error message as before Code:5,156,61 Cannot scan for these reasons: -Scanner is turned off.-USB cable is disconnected"
Any solutions to this ?
25 REPLIES 25
I've been having problems with my Canon MX892 ever since Microsoft upgraded my computer to Windows 10. I have reinstalled drivers several times. It works for a while and then stops working. Today the printer worked fine, but I couldn't get the scanner to work. Changing it to network did the trick. Not sure why. Thanks for posting this solution.
Even when printing, the printer takes a long time to print; get an error message saying the printer is not working and then it prints. Weird. Something about this printer and Windows 10. Wasn't my choice to upgrade the OS; thanks, Microsoft.
bfpike
Hello Everyone who is as frustrated by this issue as I was,
bfpike
So the solution to this problem is far simpler than the Canon people would have you believe. These Canon printers have very odd communication issues if you have multiple users on one PC. I had a very similar issue in just connecting to my wireless network after I purchased a wireless extender. If your PC is on the main network but your printer is on the extender then it fails to communicate as there are conflicting MAC addresses, IP addresses, etc.
The same sort of issues result if you are trying to scan or print from one user while the printer unit itself is trying to communicate with another user. For example;
The PC is on user: "JOHN" and on the printer unit it says at the top of the display: PC LUCY then the error will persist because the printer/scanner is trying to send information to the user: "LUCY" but that user is not currently logged on so the information hits a gap and causes the error
The solution: at the bottom of the display there should be an option that says; "Save/Forward". Click that button and choose PC then select the correct user (in this example "JOHN") and then try scanning again.
I tried virtuallly everything else including, re-installing drivers, diagnosing the printer/scanner, even tried the complex file path cut and paste solution that one Canon rep had suggested in this forum and nothing. As soon as I changed this very simple setting it worked like a charm with no problems.
I hope this helps everyone who has probably already given up and bought a different brand of printer/scanner out of spite. To the people at Canon I just have to ask, what the are they paying you for?
bfpike
Hello Everyone who is as frustrated by this issue as I was, So the solution to this problem is far simpler than the Canon people would have you believe. These Canon printers have very odd communication issues if you have multiple users on one PC. I had a very similar issue in just connecting to my wireless network after I purchased a wireless extender. If your PC is on the main network but your printer is on the extender then it fails to communicate as there are conflicting MAC addresses, IP addresses, etc. The same sort of issues result if you are trying to scan or print from one user while the printer unit itself is trying to communicate with another user. For example; The PC is on user: "JOHN" and on the printer unit it says at the top of the display: PC LUCY then the error will persist because the printer/scanner is trying to send information to the user: "LUCY" but that user is not currently logged on so the information hits a gap and causes the error The solution: at the bottom of the display there should be an option that says; "Save/Forward". Click that button and choose PC then select the correct user (in this example "JOHN") and then try scanning again. I tried virtuallly everything else including, re-installing drivers, diagnosing the printer/scanner, even tried the complex file path cut and paste solution that one Canon rep had suggested in this forum and nothing. As soon as I changed this very simple setting it worked like a charm with no problems. I hope this helps everyone who has probably already given up and bought a different brand of printer/scanner out of spite. To the people at Canon I just have to ask, what the are they paying you for?
ArienAnwamane
This worked for me.
NB I'm not affiliated with this and am about to remove the REVO uninstall programme with hopefully no repurcussions but felt it worth the effort (it was. All done in about 20 minutes)
[Mod note: Removed per Canon Community GUIDELINES regarding promotions of third party sites/services.]
GotJunior
Problem solved: Canon Pixma MG5350
Scan over USB refused showing the code mentioned.
This happened when at the same time the WIFI connection
being active. Turn the WIFI off; problem solved.
