10-08-2024 08:53 AM
I have a print mis-alignment as you can see in the nozzle-pattern, print-out picture.
How do I correct it please?
Auto & manual correction does not allow me to correct the mis-aligned characters, it all done automatically with no hands-on option. The problem remains unresolved.
10-08-2024 09:42 AM
Found the manual alignment tool - corrected everything I could find with the '+' or '-' settings, but the print-out is exactly the same for the nozzle-check. Perplexed.
10-08-2024 10:02 AM
It looks like the problem is limited to the pigment black cartridge. Have you tried replacing it?
10-08-2024 02:29 PM
Thanks John, I was just wondering, along similar lines - that the black jet/nozzle might be partially blocked?
Will update
10-08-2024 02:34 PM
I’m not familiar with that particular printer, but many have an integral print head and ink reservoir.
10-08-2024 03:02 PM
The large black ink tank was empty - ! - the printer was telling me it was 3/4 full. I replaced it with a new one. Prints are better, but the nozzle-check is the same: very odd the way everything else is good, except that one ink jet. I may have another go at cleaning the heads unit, in a day or so ~ nothing to lose.
10-08-2024 06:48 PM
Thanks. The printhead can be removed if clogged, but it's a fraught process. No, the ink is in cartridges, & the ink needs to be kept in motion, or the print nozzles dry, then clog. This may be why the head seized up, if there were empty cartridges & the printer simply wasn't telling me - then the nozzles would dry & clog. The ink display also tells me cartridges are dry, when in fact they are still half full, I wonder it there are contacts I could clean? Isopropyl?
10-16-2024 07:11 AM
The printer's working 100% now, despite that strange black tank result.
