12-25-2013 07:13 PM
12-25-2013 07:17 PM
12-30-2013 03:20 PM
Hello nichfinder,
Yes, you should be able to use the USB connection with one computer, and a network connection with another just fine. Be sure to select the correct installation method you intend to use for each computer during the installation procedure, and you will be all set.
Hope this helps!
