02-08-2019 04:48 PM
I have a Canon MX490 printer. Everytime I hit the scan button on my printer, it says "wait a while" and launches Photoshop. How can I turn that off? I just want the printer to save the scan, not lauch an application.
02-20-2019 11:49 AM
I called Canon. They had me uninstall the MP driver, reboot, and reinstall the current MP driver from the support page. Photoshop no longer launches. Thanks to all.
02-09-2019 10:53 AM
02-09-2019 05:45 PM
02-14-2019 12:11 PM
Hi Kris44dad,
You can adjust what program opens from IJ Scan Utility. In IJ Scan you will want to go to settings and adjust the open with an application under Save to PC. Please click HERE to open the online manual that will show you where you can access the option.
02-17-2019 09:30 AM
I checked all the settings on all the tabs. The application is listed as Windows Explorer everywhere. I don't see Photoshop as listed anywhere
02-17-2019 09:39 AM
Tryed resetting everything to, Don't launch any application, still lauches Phoshop when pressing the scan button on the scanner. Reset to defaults.
02-17-2019 10:43 AM - edited 02-17-2019 10:45 AM
Are you sure you have the defaults set correctly for each scan heading? If Photoshop is present, that might be the culprit.
02-17-2019 05:34 PM
Yep. I looked under every tab, and the full page under each. I still don't know what is triggering it.
02-19-2019 03:23 PM
Hello.
The IJ Scan Utility has options for adjusting the options in the IJ Scan Utility itself, and for the "Save to PC" options. The "Save to PC" options are meant for scans that are performed from the operation panel.
On the upper left corner of the Settings menu, please click the Save to PC button (middle) then make the adjustments for the tabs there.
02-20-2019 09:55 AM
I have to keep repeating myself...
When I use the IJ Scan Utility everything works as it should. It is when I use the scan button on the printer itself that Photoshop launches. I guess I will have to look on the Photoshop side for a solution. I will add that when I push the scan button on the printer, the LCD sceen says, "wait a while". It is during that time Photoshop launches. Photoshop doesn't even load an image. It just starts and sits there, making the action useless and annoying.
