01-30-2014 01:13 PM
This is a "call to arms" for all of you Canon customers who have had this problem and have had their printers disabled because of it. Please respond with the model of your printer and if you were able to fix it, what you did to fix it.
We need to put pressure on Canon to respond this product defect. It appears to be bad firmware that does not allow the user to override the problem and to continue to use the printer even in a degraded mode. From my investigations the problem is NOT a printhead issue - no way one can be printing fine and then have this error alert without having changed the printhead or ink cartridges!
Canon, PLEASE take this issue seriously and provide a solution across the affected models. If nothing else there should be a trade-in allowance for those printers that have been affected by this product defect.
I have had many Canon printers because they have superior functional specifications. I want to be able to continue using Canon products but only if I can have confidence that this product defect will not destroy my investment.
If Canon is unresponsive our next step should be to aggressively publisize this product defect on social media and on major product vendor outlet sites as negatives reviews.
Forum Users, please reply with your affected model number(s) and with details of any succdessful fix procedure.
06-25-2014 06:23 AM
This procedure worked for me Step By Step Guide to Resolve “U052 This type of print head is incorrect.”
06-25-2014 10:06 AM
06-25-2014 12:49 PM
06-25-2014 03:13 PM
If only... But the majority of us are stuck in the land of the terminally failed Canon printer with no responsible manufacturer in sight to help us... Glad it worked for you though!
06-26-2014 02:31 PM
Last night I received the dreaded message on my Mx700. This is awful. It was in the middle of an important print job. I am extremely surprised that Cannon have not addressed this issue. I have also cleaned the print head. I am going to try one more time and then purchase another brand(not Cannon).
06-26-2014 04:17 PM
Can anyone recommend a good replacement for the MX870. Need a good 4 in 1 printer.
06-26-2014 05:19 PM
06-26-2014 06:13 PM
06-26-2014 07:40 PM
Having moved on from my Canon MP610 which was great while it worked, I put it aside for a free HP printer. I held on to the Canon in the hope of a miracle cure but decided yesterday that it was not likely. However just to satisfy my curiousity I decided to dismember it to see what there was in the print head area. No finess in dismantling, just ripping off panels until I had the print head parts seperated. There were no electrical sensors or like in the ink pads but the print head carrier had a PC board with a lot of interesting components. I suspect that the "printhead error" code refers to the actual carrier and electronics that needs replacing, not the easy accessable printhead. Whatever Canon has designed into these printers is in the difficult to remove carrier and would be expensive to replace. So I kept the carrier etc and dumped the rest into the bin. I can post a photo of the dismembered carrier if someone can suggest a suitable host; ...Youtube?
06-26-2014 07:46 PM
