CP900 printer can't print multiple picutres using the software
marilynlacey
I have a canon selphy cp 900 printer I can not get it to print 4 pictures on one sheet of paper using the software that came with my printer.  It will only print one picuture and it wont' allow me to pick more picutres of the same one it's wasting my paper.  I want to pirnt mutiple of the same picture like I can if i'm using the printer with out the software.  I saw someone on you tube with the canon cp800 doing it.  why can't I I need help please.  Also I had some pictures scaned at walgreens to a cp put them in my computer and then added them to a USB stick put they wont display on my selphy printer why not.  and I can't print them with the software unless I print the 1 4x6 which I want more than one of the same picture on the 4x6 sheet which is why I got the printer.  I'm using the kp108in paper.  im fustrasted trying to make it work.  I have a project I',m trying to finish and this is holding me up.  I can print 4 on one sheet from my camera card but I need to print from my computer as well I have lots of picture on my computer I want to use and all the pictures are in jpeg.
2 REPLIES 2
Michael
Hello marilynlacey.
If you are attempting to print multiple copies of the same picture, an option to select the number of prints will be available in the "Simple Print" menu of the SELPHY Photo Print program.
If you are attempting to print multiple copies of an image on the same sheet, please use the "Layout Print" menu in SELPHY Photo Print.
For your USB flash drive, please try moving the JPEG images to the main directory of the drive.   Images in subfolders may not be read properly.  If you continue to have issues, you may have to use a different USB memory drive, or transfer the images to your computer to print from the SELPHY Photo Print program.
I have the same problem with my selphy CP800.
i cannot see the "Layout Print" .
there're three options in the Print Menu : Simple Print, Decoration Print, and Calender Print.
i cannot find the "Layout Print" in those three options, even in the Setting menu.
i elclose some screenshots of the menu.
pls help me to make multiple images on one sheet (e.g. 4cm x 6 cm photos, etc)
