03-29-2019 01:21 PM - edited 03-29-2019 01:46 PM
I don't usually print color on my one year old printer (Pixma TS 8020) but was asked about printing color from an Amazon customer so I tried printing an image. It came out horrible. Did a Print Nozzle Check and found out the C, BK and Y are not printing at all.
I don't use the printer very often which may be part of the problem. It prints B&W documents just fine. I am also using after market inks. I have tried replacing the tanks, but it didn't help.
Thanks for any help.
04-04-2019 02:47 PM
Hi harveyshot,
I recommend try a cleaning and if that does not resolve the issue a deep cleaning. Please click HERE for the steps.
The issue could also be cause by after market inks. Canon genuine inks are formulated specifically for use in our ultra-precise print head, which contains high density inkjet nozzles. If after market ink is used, it can cause issues with the print head.
04-04-2019 07:04 PM
Thanks for the reply. I've tried all the cleaning steps multiple times. Three inks work fine, the three mentioned don't work at all. Since I rarley print color, it's probably from lack of use.
I'll be throwing this one out, and the next one I'll try to print the test print once a week.
