12-17-2025 07:33 PM
If you try to operate this printer on and apple computer it can’t run maintanence. I just found this out in the most painful way. Tech support scambled to find a link for a patch or an app for the apple users maintenance… and failed. (I was told to find a new computer) wow
12-18-2025 09:57 AM
To perform maintenance on your Canon PIXMA G1220 directly from the printer control panel, follow these steps:
Power On the Printer: Ensure the printer is turned on and ready.
Navigate to Maintenance Menu:
The following maintenance functions can typically be accessed:
| Function | Description |
| Cleaning Print Heads | Cleans the print heads to prevent clogs. |
| Align Print Heads | Aligns the print heads for optimal print quality. |
| Nozzle Check | Prints a test pattern to check for clogged nozzles. |
| Cleaning Paper Feed Rollers | Cleans the rollers to ensure proper paper feeding. |
Regular maintenance helps keep your Canon PIXMA G1220 functioning well. Use the control panel to access these features easily and ensure high-quality prints.
12-18-2025 06:36 PM
OK i can run THAT maintenance but not the flow purge function (I have pressed all the buttons) Canon is letting me down by skimping on the software I need to do this maintenance. But only for the apple user. Thank you. That doesn’t resolve my issure sorry
