08-22-2021 05:50 PM
I'm using a CANON TR4520 printer. I use a utility provided by CANON to scan documents to a PDF, but it can't scan to a PNG file. I'm told that isn't a flaw of the utility, but rather the TR4520 doesn't support that function. Does anyone know of a CANON printer similar to the TR4520 in terms of price and capability (except for the absence of PNG capability)?
TIA.
pwrichcreek.
10-27-2021 03:24 PM - edited 10-28-2021 07:54 AM
Hi pwrichcreek,
The IJ Scan Utility can save your scans as PDF. Please open the IJ Scan Utility and follow these steps:
1. Click the Settings button in the lower right corner.
2. Click on Photo Scan in the menu on the left side.
3. In the Save Settings section to the right, select PNG from the Data Format drop down box.
4. Click OK.
5. Place your item face down on the scan glass and click the Photo button on the IJ Scan Utility.
Your item will be scanned and saved as PNG.
Hi pwrichcreek,
4. Click OK.
10-27-2021 05:47 PM
Hi Patrick,
. Place you item face down on the scan glass I had been loading the document into the multi-page feeder, I guess because that's what I always did for pdf.
Thanks for you help.
pwrichcreek.
