2 PIXMA MX922 printers; the same old error message 6000
ERad
I received my refurbished PIXMA MX922 printer, serial #AEWS71102, as a replacement for a printer I bought in April (serial #AEYH44826).  After working well for two weeks, the first printer continuously displayed an error message 6000 that could not be corrected by means suggested by Canon support.  The refurbished scanner was sent, and it arrived on May 2, 2017.  I have been out of town, and did not have any opportunity to connect the new printer to my PC, according to the instructions with the printer, until today (May 7).
Unfortunately, the replacement printer does not work.  After loading the special paper needed for print head alignment, there was no ink deposited on the paper and the machine displayed error message 2500.  Per the displayed instructions, I deactivated and unplugged the printer, reloaded the paper, and then restarted after reinserting the plug into the outlet.  The printer then displayed error message 6000 without performing any other function.  I shut down the printer and unplugged it.  I then checked the print head, which was seated, though the lights that signify the ink cartridges are locked into place no longer light (despite lighting when the ink cartridges were first installed).  I removed the ink cartridges and reinstalled, but that had no effect after restarting the printer.  Despite going through those steps, it continues to display error message 6000.
After a very brief lifespan, my original printer failed, and, now, the replacement has failed with the same error message 6000. To put it mildly, I am unhappy to now be in possession of two non-functioning PIXMA MX922 printers.  This is not the type of quality I expect from a reputable name, such as Canon.
I am open to suggestions.
Michael
Hello.
Please try the following to see if we can resolve your issue:
1.  Turn the printer off.
2.  Unplug the power from the printer for at least 5-10 minutes.
3.  While unplugged, remove any paper from the unit.
4.  Double check for any obstructions found in the unit or paper paths.
5.  If no obstructions are found, plug the power back in and turn the unit on.
If the issue persists, troubleshooting with our support group will be needed to narrow down the cause of your issue. Please contact our support group using the "Contact Us" link below for additional assistance.
4 REPLIES 4
Michael
Hello.
My PIXMA MX922 is brand new. It will not start. I just get the Error 6000 message. I tried all of the suggestions and I still get the same message. When I try to call Canon the virtual assistant asks for the phone number associated with my account. I put in the phone number and the virtual assistant says that it isn't recognized. I've tried this 8 times and I always get the same message. I'm sure the phone number is correct. Is there a way to chat with someone? Or reach a live person in a way that doesn't involve calling the service number? This is maddening.
If the printer is out of support life, you will have the option to contact our phone team only.
Please be advised if the error does not clear after trying the steps HERE, the printer will require service.
If the printer is in its 1-year warranty, I recommend reaching out to Canon support for your warranty options. You will need to register your Canon gear HERE to access additional support options.
If the printer is out of warranty, you would qualify for the Canon Upgrade program. This is for out of warranty units which have been diagnosed to require service or are incompatible with a new or upgraded system. This program allows you the opportunity to purchase a replacement product discounted from the list price. Free ground shipping is included with your purchase.
You can take advantage of this offer by calling the Canon Sales Department at (866) 443-8002 Mon-Sat, 9 AM to 9pm EST excluding holidays.
