10-26-2016 11:21 PM - edited 10-26-2016 11:26 PM
Can someone let me know if you can disable this from auto launching. I would like to use capture one and have the eos utliity on my computer as a backup plan. With the eos utility auto launching it will not allow capture to mount the camera. I tested it on my tower where I don't have the utility and capture works perfectly. So I am thinking it's the auto launch feature or it could just be that eos is installed and that takes priority.
I'm using eos utility 2 - 2.14.20.2 with a mark II
my os is Yosemite 10.10.5
Thanks in advance for any help
Cheers,
Brad
11-03-2016 03:41 PM
freaking stupid! that was rignt infront of my face! Thanks now i can sleep agian.
Cheers
11-03-2016 03:58 PM
Glad to help.
03-01-2017 07:49 PM
Unfortunately, on a Mac, the EOS utility version 2 & 3 will force themselves to be listed once again on the user's auto login/startup list anytime you use the utility. So go ahead, tell it not to autostart when a camera is connected. Remove the stupid utility from your list of auto login items, EACH AND EVERY TIME YOU USE it.
What a feature !!!!
03-01-2017 08:07 PM
On my Mac the "do not launch" check mark is sticky, so connecting a camera won't launch EOSU, even though EOSU is in the top bar (not sure what its called).
05-14-2017 02:19 PM - edited 05-14-2017 02:25 PM
SImilar problem on windows. It always starts up, but can be set to not open the up a window on camera connect. Rather annoying to have it open at all. For Windows (assuming you removed it from autostart), when you start it up manually it adds itself to the users STARTUP folder.
06-08-2020 03:42 AM
1. Sytem Pref -> Users & Group -> Login Items
2. Select EOS utility
3. Click '-' button on the boom
4. Reboot
06-08-2020 06:01 PM
@fpenguin wrote:1. Sytem Pref -> Users & Group -> Login Items
4. Reboot
Don't know if applies to macs, but definitely doesn't to PC users. No such option as login items.
10-12-2023 11:34 AM
Its 2023 and im still having a hard time trying to fix this bug. I cant seem to see the pictures attached to your solution. Do you mind posting them again? Thanks!
