Zoombrowser HELP can I transfer my keywords into another program
JJK
hi
I have recently installed Windows 10 & and Zoombrowser  no longer works. I believe imagebrowser is also not available for Windows 10.  I would advise by Canon technical support that they do not have another program for editing photographs.
I have 20 years worth of photographs all tagged with my special keywords-my  lifework!
can the Metadata(if that is the right term) within these photographs be picked up by another program that I could use?
Thanks
11 REPLIES 11
I found this via Google:
ZB Meta Save - Browse Files at SourceForge.net
It i discussed here:
Solved: Zoombrowser tags - exporting to Imagebrowser - Canon Community
I can make no guarantees, but maybe it will help you.
Also, maybe you can find an old PC somewhere that will run ZB or dual boot your PC.
Thanks
That's the program I used before to transfer the information. I just need to find another program now that can import that data.
Thank you for your help
John
