Windows 8 and Rebel Xsi
Vianna
     The  new computer I bought comes with Windows 8 and I can't upload the photos from my Rebel XSi now. I installed the software that came with my Rebel (ver 17.1) but it must be outdated. Or is there a different reason?
If it's the outdated software, can someone please direct me to the new downlad link? Here's the link to the only information I found - which isnt much or helpful:
http://www.usa.canon.com/cusa/support/consumer/eos_slr_camera_systems/eos_digital_slr_cameras/eos_re...
Thank you - and happy thanksgiving.
20 REPLIES 20
you the man
worked perfect first time
whoooooo hooooooooo
I have a Rebel Xti, I see all the colored icons on the menu, but there is no option for communications on the 2nd amber set up icon 😞 I wonder if it isonly on the XT??
I have teh Rebel Xti, there isn't a communication item option. Anything I can do to get my pics directly offf the camera or do I have to use the SD card?
Hi Colleen,
Unfortunately, I only have an XT and am still stumbling around that. Can't help with the XTii.
Hello Colleen,
The EOS Rebel XTi does not have a communication mode.  It should be able to make a direct connection to the latest operating systems.  Since you mention using the SD card, it would be worth noting that downloading direct from the SD card, either via a memory card reader or through your computer directly, would be the most direct method.
I uploaded the new utility software but my problem persists;  my problem is that Windows doesn't even seem to find the camera (doesn't beep or show up on the My computer screen);  I tried other USB devices in the USB slot and they work and I tried the camera/cable on a windows 7 system and it worked fine.  I tried troubleshooting devices but it said there were none.  What am I missing?
I FOUND OUT THAT i CANNOT USE THE eos UTILITY BUT IF i CONNECT THE CAMERA DIRECTLY TO THE COMPUTER IT DOES WORK.
Cheers Greg....have been following all manner of advice. Wish I found this first. ... this fixed it straight away - camera instantly recognised with Windows 8. Bless
my problem turned out to be that the USB ports on the front of the computer did not recognize the camera but the port on the back did,
Perfect! worked first time. Thanks
