06-07-2016 07:19 AM
When exporting images from CR2 into TIFF format. It creates one file, but when clicking into that file it becomes two images. One is like a thumbnail version and the other is the tiff file that i need. How do i get the export to not create this additional image and just the TIFF version? It works fine when creating a JPEG.
06-07-2016 08:01 AM
What software package are we talking aboiut?
06-07-2016 08:04 AM
Oh yes sorry DPP4
06-07-2016 08:14 AM - edited 06-07-2016 08:16 AM
@lmliam wrote:When exporting images from CR2 into TIFF format. It creates one file, but when clicking into that file it becomes two images. One is like a thumbnail version and the other is the tiff file that i need. How do i get the export to not create this additional image and just the TIFF version? It works fine when creating a JPEG.
How would I go about reproducing this phenomenom? Mac or Windows? What does "clicking into that file" mean? Etc.
[EDIT{ BTW, I never create TIFF files. JPEGs work just fine. TIFFs tend to hog memory.
06-07-2016 08:24 AM
My procedure would be to highlight a bunch of images in DPP4 and then select file and batch process. In the settings i would select destination, save as type TIFF 16bit, output resolution 400dpi. Then click convert raw images only.
It is when opening the TIFF file later in Windows photo viewer that the two images appear. (However in the settings it still says single file)
06-07-2016 08:31 AM
@lmliam wrote:My procedure would be to highlight a bunch of images in DPP4 and then select file and batch process. In the settings i would select destination, save as type TIFF 16bit, output resolution 400dpi. Then click convert raw images only.
Ignore it. Windows uses JPEG files for previews, not TIFFs. I'll leave it at that. By default, Windows hides those files from users.
06-07-2016 10:02 AM
06-07-2016 10:08 AM
Ignore it. Stop looking for problems where none exist.
Where are you saving the output files from the batch process? Same folder as the originals? Take a careful look at the filenames that the Windows Photo Viewer reports for each image. I bet you lunch that one of them is CR2, and one is TIFF or JPEG,
06-07-2016 10:17 AM
Thankyou for your input but ignoring it isnt going to help. Yes they are both Tiff files because it is one file and both of the same file names. If anyone else has expirienced this problem?
06-07-2016 10:30 AM
