04-12-2023 12:24 AM - edited 05-06-2023 09:15 PM
5/6/2023 Update: I did more testing today. The location stored in every photo is the location where the phone was when you "Start recording." Every photo taken that day will have that GPS coordinate, and though the photos have the correct time, the GPS timestamp will be the same as well. (3.0.11.24 build 1341 was used today, same issue.)
I tried the updated Camera Connect last week. I was running the 3.0.10 (or it might have updated to 3.0.11 by then) on an iPhone 14 Pro with 1TB storage. When I used the version available in October 2022 (probably 2.9.22), it still had the issues where it would often just stop logging during the day. I had days on that trip where I forgot to keep checking it, and lost half a day or more of GPS data.
The new version looked like it was working better, since it was always still logging each night when I went to shut it off and upload GPS data in to my Canon G5X.
Unfortunately, tonight I found out it only put in SEVEN (7) GPS locations in the 4300 photos I took over the five days. They ALL have GPS data, but it's one of the seven locations repeated through thousands of photos.
4/12 UPDATE: Using ‘exiftool’ it now appears that the SAME GPS date/time and lat/lon is embedded in every image taken the same day, so my 7 locations were from the 7 days I used the camera, it seems.
I confirmed this using the 'exiftool' command line, and a script I had ChatGPT help me write (https://github.com/allenhuffman/EXIFPhotoScripts/)
This is a huge failure. Fortunately, due to all the problems I've had with Camera Connect over the past five years, this trip I ran a "Geotag Photos 2" app as well, though I did not have it logging as frequently as I would have liked. I hope to be able to use it's data to at least get my photos in the general area they were taken.
This is a big disappointment, since I recently created a script that lets me draw out regions in a Google Map, export it out as a KML file, then let the script sort photos in to subfolders based on the areas drawn on the map. This turned a sorting process of photos from Knott's Berry Farm in to a half hour process instead of spending a week or more working on it by hand.
Anyone had this problem? It shows 3.0.1 came out 5 months ago (no note on GPS changes), then 3.0.10 1 month ago (new camera support) and then 3.0.11 a week ago.
11-06-2023 02:25 AM
Same problem with EOS RP and iOS App v 3.1.10.50 (build 1385). I have also lost geo tagging of hundrets of photos 😞.
11-06-2023 09:57 AM
I tried iPhoneOS version 3.1.10 two weeks ago, and it still has the provlem. I am using Geotag Photos 2, and GraphicConverter on Mac to place the coordinates in my photos later. Geotag also lets me export the GOS data so I can open it up in a map, which is something I had asked Canon about years ago for a feature.
11-06-2023 12:23 PM
Workaround for Lightroom Classic Users:
Voila - your pics are now geotagged. In my case the altitude is saved in metadata too. I like this workflow, because I must not take care for Camera Connect App anymore. I can focus on shooting.
11-10-2023 02:29 PM - edited 11-10-2023 07:16 PM
Camera Connect Version 3.1.10.50. iOS Version 17.1.1. Canon EOS M200.
Just ran a test today. Took some random photos while I was running errands. GPS data transferred to the RAW camera files and location displays in Lightroom Maps.
11-19-2023 12:11 PM
Same problem here. CC version is 3.1.10.50 (build 1385), installed on an iPhone 13, and camera is a Canon G5X. All was well with my old iPhone 6, and the latest version of CC that it could install.
GPS data recorded for the first picture, but then repeated on every other picture in that session.
03-31-2024 04:26 PM
Since Canon does not offer repair services on their point-and-shoots, I may be about to move to a new camera. Unfortunately, due to Canon not being interested in supporting things like the GPS app, it will likely not be a Canon. Until then, has anyone had any success with this app on a G5X?
09-12-2024 03:48 AM
Go to the Wireless settings screen. Before each change in location, cycle Airplane mode on and off. The camera will then update with the new GPS setting. Alternatively, cycle Bluetooth settings thru Disable and Enable, or cycle GPS settings thru Disable and Enable. After each cycle, the camera will update with the new GPS setting.
09-13-2024 03:34 PM
I have kept my old iPhone 6 going for this very reason. It cannot use V3.xxxxx of Canon Connect, but the App Store will offer the latest 'compatible version', which is V2.7.50.25 (build 1238). This is still available and it works perfectly with my G5X.
11-10-2024 09:45 AM
I was running into the same issue intermittently. Today I tried toggling the iOS location permission for the Camera Connect app to "Always" under "Allow Location Access." It was previously set to "While Using the App." That change resulted in accurate geotagging for now. I'll report back if that changes.
This is iOS 18.1, Camera Connect v3.2.30.34 (build 1409), on an iPhone 15 Pro. The camera is a G5 X M2.
12-17-2025 09:00 AM
I have Camera Connect Version 3.5.11.15 (build 1430), iPhone 16 Pro Max with iOS 26.1, Canon EOS R5 Mark II with firmware 1.2. I had this exact problem yesterday. All my photos were tagged at the place where I started Camera Connect. I will go out today and try setting "Always" for Camera Connect.
No one has mentioned using GaiGPS. That will be my fall back plan. Indeed, I may just go with it and forget Camera Connect completely. I turn Airplane mode off each time I start photographing (if I don't forget) and then I turn it back on to save batter life each time I stop. Plus, I have to start up Camera Connect and I have to worry that it is connected. Why bother? Instead of all that, just start GaiGPS (or Geotag Photos 2 -- it looks like it is doing the same thing. Then I have all of my tracks. It is a tiny bit of pain to download the tracks and get LR to do the tagging I suppose.
The other plus is when the phone loses GPS briefly. At that point, the camera will have no GPS data. If a tracker like GaiGPS or Geotag Photos 2 is used, LR will make an estimate of where you were based upon the two point before and after via time stamp. Not precise but better than nothing. This may be a big win actually.
But I will try the "Always" setting today as well and report back.
