Using Canon Camera Connect with Two Cameras
ChrisJ
There is probably a simple answer to this but I can’t find it. I’m running two Canon cameras. Can I readily switch between them on the Canon Connect app or do I need to download the app twice? I am able to switch using the side menu but it’s a pretty tedious process. Likewise, I want to download RAW images to Canon DPP Express. Simple advice please for a simple person!!
For the CC App, yes sir.  Once connections are made, you can swipe back and forth between saved camera profiles and connect on demand.
The DPP Express App works after the images are downloaded.  Start by downloading the photos you want to edit.  Note, for iOS you have to tell the CC app to download RAW files.  Its a toggle.  **This feature is not available in Android.  After that, you open the DPP Express App, navigate to the folder where your RAW images are saved and open to edit.  The CC App creates a separate folder for each camera when images are transferred.
On my phone I have profiles and folders for R5 C and 6D MKII.
4 REPLIES 4
Hi Chris,
Your device will only allow one instance of the Canon Connect App or Canon DPP Express to be installed.  You can have multiple camera's paired to each app, but only one can connect or be controlled at a time.
Okay. Thanks. But how easy is it to switch between the two cameras? Can they both appear in a menu, for example, so you can click on the one you wish to use currently?
Thanks. I’ll give it a go.
