09-26-2023 08:55 AM - edited 09-26-2023 09:06 AM
I am having issues connecting my Canon EOS R5 (Latest firmware 1.9.0) to my Mac on latest macOS 13.6 via the EOS Utility 3.17.2.1 (latest)
I have the latest software and have gone through the user manual.
I have uninstalled canon Software and reinstalled without any improvement...
The message I keep getting is:
"Communication with the camera via USB cannot be established.
Start EOS Utility after closing all the apps that communicate with the camera, and then turn on the camera again."
I am unaware of any apps that I have that would be trying to communicate with my camera in the background. Anyone know what's going on? Thanks in advance.
09-26-2023 12:28 PM
Programs such as Google Drive or cloud storage programs can interfere with the EOS Utility. Also, having Canon's EOS Webcam Utility installed will cause the EOS Utility to fail to connect to the camera.
10-10-2023 04:34 PM
I was having also having a similar problem connecting my EOS R5 to a Mac mini M2 running Ventura 13.6. I use the USB-C to USB-C cable from Canon that was included with the camera.
Earlier in the day, I launched the application to be able to download some recent photos but got the same alert. I was initially confused because I wasn't aware of any running program that would cause this type of conflict (such as Image Capture).
I eventually determined that Preview was running even though it wasn't displayed in the Dock. Once you realize that this could be an issue, the workaround in quite straightforward:
I was then able to connect using EOS Utility 3 application and eventually download my images.
Hopes this helps some people.
- Pie Lover
P.S. I called Apple Support to report this issue. A Senior Apple Advisor suggested that people experiencing this particular issue consider filing a bug report using the Apple Feedback site
11-02-2023 09:26 AM
This method should work without having to resort to a Force quit (which may cause issues):
- Pie Lover
02-24-2024 02:48 PM
@Blueberry_Lover,
Thanks for the tip about Preview. This was exactly the issue I was having. Preview was open and the EOS Utility could not connect to my camera. Closing Preview let it connect immediately.
Who would have thought that Preview was connecting to the camera?
I had successfully connected to the camera from my MacBook Air previously, but this was the first time connecting from my MacBook Pro, so I was really confused as to why it didn't work.
Thanks again!
02-24-2024 07:34 PM
My pleasure. It seems like Canon isn't updating their tools to track the macOS releases and updates. I've experienced problems with DPP crashes (with Apple HEIC files) and EOS Utility 3 downloads. For the latter, the automatic download option stopped working a while ago so I use the select and download option instead.
- Pie Lover
