Porting RAW edits from DPP to DPP4
cg5
I was using DPP and switched to DPP4 in 2020. Image edits (brightness, contrast, crop, etc.) made in DPP do not port to DPP4, so if I want to reedit those images I have to use DPP.
(1) Is there a way to port the edits made in DPP into DPP4?
(2) If no, will there be a way to redownload DPP in case I need to, e.g. get a new PC?
Thank you.
4 REPLIES 4
jrhoffman75
What camera did you have when you downloaded DPP?
Maybe the support page for that camera has the software? Also, some camera support pages have digital images of the CDs that came with the camera.
JR, thanks. Camera is EOS 70D, but I’m confused by question since DPP and DPP 4 are downloaded to a Windows laptop. I’ll look into the CDs that came with the camera as you suggest, that may solve item (2) if there’s no solution to (1).
DPP is DPP regardless of the version number behind its name. Digital Photo Professional (DPP) has evolved by adding features and support for different file types and operating systems, but the files it supported in earlier versions are the same which are supported today. .cr2, .cr3, etc.
If you edit files and don't save them, your edits will not migrate to another computer or install of DPP.  You either need to save the files before moving or copy over the recipies you created in an earlier version of DPP.
I think they are saved in C:\Users\%userprofile%\AppData\Roaming\Canon_Inc_IC (by default)
MAC is obvoulsly different.
You can save recipie files, export and import.  This should allow you to move unsaved edits between your installs.
jrhoffman75
Go here:
https://www.usa.canon.com/internet/portal/us/home/support/details/cameras/eos-dslr-and-mirrorless-ca...
Go to the operating system drop down and select Windows 7. There you can download a digital image of the original CD that came with the camera. There is also an updater to DPP3.15.
But, with the CD image you will have DPP3, so just use it with the previously edited images. DPP3 and DPP4 can coexist on the same computer.
