07-07-2016 02:40 AM
Dear All,
I have brought Canon 5DS in october 2015. I had been using DPP software which allowed me to convert RAW files into JPEG. I have also used HDR option as well.
lately, when i try to do this, batch process do not process at all, if i use Start HDR , it also do not create, just keep processing.
I am not able to process any RAW file now.
i had searched a lot on google but no results. today i came to know about this canon community
Requesting your help.
Regards
Amit
07-07-2016 06:27 AM
Are you uisng DPP 4.4.30 (latest version)?
07-07-2016 12:28 PM
@jrhoffman75 wrote:Are you uisng DPP 4.4.30 (latest version)?
DPP 4 tends to be a resource hog. It's slow, and I suspect it of having memory leaks. So be sure that you run it on a computer with a fast 64-bit processor and plenty (6 GB or more) of memory.
DPP 3 seems a lot more efficient, but lacks a number of nice features found in DPP 4.
07-07-2016 12:35 PM
Bob is right about the speed issue. Can you process one image OK?
You can select Batch Processing with just one image to determine if its being overloaded by many images.
07-07-2016 02:16 PM
hi, i was using 1.3 now installed latest one and it is working thanks
07-12-2016 01:42 PM
@amitgargi wrote:hi, i was using 1.3 now installed latest one and it is working thanks
"Bob is right about the speed issue. Can you process one image OK?
You can select Batch Processing with just one image to determine if its being overloaded by many images."
What's the answer to his question? Can DPP perform a regular RAW to JPEG conversion, or not?
07-12-2016 01:44 PM
yes friends. now it is working fine. I am able to process files in a batch as well.. thanks a ton for your help
07-12-2016 01:47 PM
