06-26-2022 08:00 PM
06-27-2022 02:35 PM
When you say does not solve the problem, are you referring to my first attempt or second one? The way to do this is to download the files in sent in my last previous post onto a USB drive and use that to do the install from. I tried it and it worked for me on another computer. I am using Windows 10 Pro.
06-27-2022 07:03 PM
it works; technical changes between 2009 and present upgrade are considerable.
06-27-2022 07:12 PM
I believe this is very likely a correct solution. I found that my navigation skills were not up to the task, so I eventually went with a different solution which seemed a bit more straightforward for my skill level.
Thank you for your interest and help.
06-27-2022 07:28 PM
it does. thank you.
06-27-2022 07:31 PM
I believe it is a solution. my navigational skills are not up to this one. I found another route that is a bit easier (for me).
