Need original EOS Utility (CD) for my EOS 5D Mark ll
88mesonx
Does anyone have an original EOS Utilities CD?
14 REPLIES 14
When  you say does not solve the problem, are you referring to my first attempt or second one?  The way to do this is to download the files in sent in my last previous post onto a USB drive and use that to do the install from.   I tried it and it worked for me on another computer.  I am using Windows 10 Pro.
cheers, TREVOR
it works; technical changes between 2009 and present upgrade are considerable.
I believe this is very likely a correct solution. I found that my navigation skills were not up to the task, so I eventually went with a different solution which seemed a bit more straightforward for my skill level.
Thank you for your interest and help.
it does. thank you.
I believe it is a solution. my navigational skills are not up to this one. I found another route that is a bit easier (for me).
