Need EOS Utility 2 for T2i remote live shooting
t2iuser
I need to do remote live shooting on my T2i but I don't have the EOS Utility installation CD with me anymore. I tried to download the software from the Canon Support website for T2i but it lists only the EOS Utility 2.14 updater (same for T3i/T4i). How do I obtain the EOS Utility 2 software?
FloridaDrafter
Assuming you are using Windows... On the T2i support page you can select an older Windows version and download a digital version of the Solution Disk that came with the T2i. Just scroll down a bit to find it and you may have to select "Load More" to get there. Then apply the Updater. I selected Windows 8.1(x64).
Newton
5 REPLIES 5
NatalyaP
Greetings t2iuser,
The EOS Rebel T2i camera was designed to work with EOS Utility 2 but this software application is no longer supported and no longer updated for newer operating systems. The software is no longer available for download. Unfortunately, EOS Utility 3 will not function with this older Canon camera. I do apologize for any inconvenience this may cause.
normadel
I have the full original EU2 installer file. I can supply it to you. Private-message me to work it out.
After installing it you should apply the 2.14a Updater.
FloridaDrafter
Newton
Thanks a lot normadel! I appreciate this gesture! I also confirmed that the download is available after selecting an older version of windows as FloridaDrafter had suggested later.
Thanks a lot for this find! This is a great workaround!
