09-28-2015 10:53 AM
I'm connecting my t6s to my smartphone using Camera Connect. I can view the images on the camera just fine but when I download them to the phone they are resized to 1920X1280. I'd like to be able to transfer the full size image but can't find any setting to do that. The camera itself gives me option for full or resized when sending to web service like Canon Gateway but no such setting is apparent for smartphone connection.
09-30-2015 10:51 AM
Hi windycityart!
Thanks for posting.
The Camera Connect app does not have the ability to transfer RAW or full sized images. Images that are transferred are resized. To upload full size images, this will need to be done using the EOS Utility software on a computer.
09-30-2015 10:51 AM
Hi windycityart!
Thanks for posting.
01-22-2016 05:24 PM
01-22-2016 06:48 PM
I discovered that if you touch the three bars at the top right while you're viewing the image on your phone you can choose settings and you'll see one called Resize. You can choose Resize, Don't resize, or Select when saving. I think it is new.
01-22-2016 07:15 PM
04-06-2016 08:46 AM
Ok, there is option to not resize, but on my iPhone the image size is only 1920x1080 which is not full size of the image. Any suggestion?
04-06-2016 10:02 AM - edited 04-06-2016 10:03 AM
@dexter77 wrote:Ok, there is option to not resize, but on my iPhone the image size is only 1920x1080 which is not full size of the image. Any suggestion?
The reply by the Moderator Mykolas , just above, may contain your answer.
04-06-2016 10:08 AM
The answer is from 2015, I think that app has changed since that time, because there are additional options.
I don't understand how it works - there's no difference if you choose resize or don't resize, image size is the same.
04-06-2016 10:33 AM
Maybe, that actually is the size of the image stored in the files. Hmm?
04-06-2016 03:35 PM
I just tried it on my new Android phone and it transferred the full size image at 6000 X 4000. If I choose resize it comes over at 1920X1280.
