Eos utility is not working (Canon 70D)
tsouza29
I tried to use the EOS utility 2 with my Canon 70D, but apparently the software is not recognizing the camera and I was not able to figure out how to solve it. I also have used with my T2i, but it worked fine. I'm using windows 10.
Does anyone know how to solve this problem?
Cheers
10 REPLIES 10
How are you trying to connect? Via WiFi or USB cable? I forget whether the 70D has WiFi; but if it does, you probably won't be able to connect via USB cable unless WiFi is turned off first. The camera's instruction manual should tell you how to do that.
Bob
Hey Robert,
Thank you for replying.... Yeah I'm trying to connect via USB and yes, my wifi is turned off. Do you have any other suggestions?
Sincerely
Tiago
@tsouza29 wrote:
Hey Robert,
Sincerely
Tiago
The 70D is a fairly recent camera, so you might try EOSU 3 instead of EOSU 2. The way EOSU 3 works is that it decides, based on the camera it sees, whether you need EOSU 2 or 3 and starts the correct one. Correspondingly, installing the latest edition of EOSU 3 will install or update EOSU 2 as well. At least that's how it is on a 64-bit Windows computer.
Bob
Hi Robert,
I've tried EOSU3 as well and I had exactly the same problem. I found a "workaround" that was using the wifi connection to make the EOSU to see my camera. Sending photos to PC is a way slower than via USB, but it worked at least. I'll keep trying to connect it via USB and if I have any news I post it here to all
Cheers
Tiago
@tsouza29 wrote:
Hi Robert,
Cheers
Tiago
Are you using the same USB cable that worked with your T2i? Some USB cables have the charging wires but not the data wires. Obviously such a cable wouldn't work for you.
Bob
Yeah Robert.
I'm using the cable of my Wacom tablet, but I've tried with different ones and unfortunatelly I had the same results for all the cables I tried.
Do you recommend me to update the firmware of my camera for the last version?
Cheers.
@tsouza29 wrote:
Yeah Robert.
Cheers.
Try disabling the Wi-Fi when you try to connect to USB?
"Fooling computers since 1972."
Yeah @Waddizzle....
Firstly I was trying to connect with the wifi disabled without success... I will try to connect in a windows 7 to see if my main problem is on the camera, EOSU or the windows version.
at405r
Having the same issue but with WiFi. It:
- sees camera on computer
- click connect
- click connect on camera
- the pair window disappears on the computer and then nothing else comes up. It won't open or work with manual open on EOS Utility 2 or 3. I tried different versions.
Maybe the camera needs a firmware update? I saw one 9/30/16. I have a Mac.
