11-14-2012 02:28 AM
Hi to all,
I have a problem with the Eos Utility Software.
I have the OS Windows 8, and I installed the last version of EOS Uility 2.12 compatibility with the new OS.
When I connect my EOS 5D MKIII or the 7D the EOS Utility not recognized the camera.
The drivers are installed , all the others programs works fine with the cameras.
Someone have a suggestion ? ![]()
12-04-2012 06:48 AM - edited 12-04-2012 06:50 AM
richk107 has identified the key to the problem.
I first disabled all the entries in the 'portable devices' tab in device manager and voila the EOS utility detects a camera attached.
I then went thru each entry enable them one at a time and checking the EOS utility. One particular drive was the cause, which is the drive mapped for the ms/ms-pro memory card slot.
Seems the detection mechanism needs to be reworked a little, though at least there is a work around in the meantime.
02-17-2013 02:46 PM
Hi All - First time poster here. Has this problem been resolved? I have read through this and many other discussions on line and tried everything suggested but still unsuccessful.
I have an EOS 30D and have used it for years with the Canon Utility provided, and Windows XP, with no problems.
I recently had to change computers at work, and soon after at home. One is a Dell XPS 8500 desktop, and the other is a Lenovo T420S laptop. What they have in common is both are running Windows 7 64 bit, and I cannot get either one to operate with the Canon Utility. I have tried the original EOS Utility 1.0.17, as well as downloaded 2.9.0.0 and 2.12.3.1.
It always in the end comes up with "Failed to communicate with the camera. Check Connections". I have tried every USB 2.0 and 3.0 port and 2 different cables.
I have gone into the device manager and disabled everything under Portable Devices. Nothing helps. Any resolution or new ideas?
Thanks!
02-21-2013 08:38 AM
Hi runner,
The EOS 30D may also appear as a portable device. Please make sure you have not also disabled the camera by mistake.
What other devices, aside from the camera, do you have connected to your computer?
02-23-2013 05:16 PM
I have the same problem, and do not have any card readers or "Portable Devices" connected to my PC running Windows 8 64-bit.
This is definitely a real problem, and while others may have found a way to work around it when they have "Portable Devices" interfering, it still persists and I have only 1 item under "Portable Devices" in Device Manager: My Canon Digital Rebel XTi.
I am using the Windows 7 x64 EOS Utility as there is no EOS Utility download for Windows 8 for the Digital Rebel XTi. ![]()
1. Power on Camera
2. EOS Utility loads, flashes on the screen, and disappears immediately.
Windows Event Viewer shows the following logged:
Faulting application name: EOS Utility.exe, version: 2.0.2.30, time stamp: 0x4a51b822 Faulting module name: EDSDK.dll, version: 1.2.0.5, time stamp: 0x46d40420 Exception code: 0xc0000005 Fault offset: 0x0001e3e0 Faulting process id: 0x1570 Faulting application start time: 0x01ce12125826429e Faulting application path: C:\Program Files (x86)\Canon\EOS Utility\EOS Utility\EOS Utility.exe Faulting module path: C:\Program Files (x86)\Canon\EOS Utility\EOS Utility\EDSDK.dll Report Id: 98e280d9-7e05-11e2-be76-00219b225d7a Faulting package full name: Faulting package-relative application ID:
And also:
Fault bucket 1602806191, type 1 Event Name: APPCRASH Response: Not available Cab Id: 0 Problem signature: P1: EOS Utility.exe P2: 2.0.2.30 P3: 4a51b822 P4: EDSDK.dll P5: 1.2.0.5 P6: 46d40420 P7: c0000005 P8: 0001e3e0 P9: P10: Attached files: C:\Users\jblaine\AppData\Local\Temp\WER4FE2.tmp.WERInternalMetadata.xml These files may be available here: C:\Users\jblaine\AppData\Local\Microsoft\Windows\WER\ReportArchive\AppCrash_EOS Utility.exe_3abf1c4a326ee6ee266305673e7fbe3bc3d4e5c_1eb65223 Analysis symbol: Rechecking for solution: 0 Report Id: 98e280d9-7e05-11e2-be76-00219b225d7a Report Status: 0 Hashed bucket: 948079266429306335cf8d72bebbd9a3
This is a big bummer, as I relied on EOS Utility to easily copy then delete images from my camera.
02-26-2013 10:41 AM
Hi jblaine,
I noticed in reading over the event log that you are using a much older version of EOS Utility, version 2.0.2. In order to get this working, you need to update to the latest version that supported the EOS Rebel XTi, version 2.9.0. This update can be downloaded from our website. I included a link to the download page below:
03-13-2013 07:19 AM
I have the exact same problem.. I have installed Canon Utilities EOS Utility Version 2.12
I get the following error when I connect the camera (a 400d) which is a Rebel in the US
When I run the utilit without the camera connected it works ok...
the error is
Faulting process ID: 0x1d0c
Faulting application start time: 0x01ce1fdb24e4d5e0
Report ID: 6ae97f23-8bce-11e2-be94-1c6f65f9263d
Can someone help us this is getting frustrating!
05-12-2013 03:19 PM
Hi Mike,
I am also having the EOS Utility problem with my Rebel XTi EF-S 18-55. I have tried all the previous suggested but continue to have the same problem. I clicked on the link you provided to jblaine for the most recent EOS Utility version. Unless I'm mistaken, it looks as though EOS Utility was not a download option.
Any suggestions?
05-20-2013 02:24 PM
06-02-2013 05:55 PM - edited 06-03-2013 01:33 AM
Hello,
got exactly the same issue when I'm powering on my EOS 400D : EOS Utility loads, flashes on the screen, and disappears immediately.
Here's the error in Windows Event Viewer :
Nom de l’application défaillante EOS Utility.exe, version : 2.0.2.30, horodatage : 0x4a51b822 Nom du module défaillant : EDSDK.dll, version : 1.2.0.5, horodatage : 0x46d40420 Code d’exception : 0xc0000005 Décalage d’erreur : 0x0001e3e0 ID du processus défaillant : 0x15c0 Heure de début de l’application défaillante : 0x01ce5fd8291b1a9a Chemin d’accès de l’application défaillante : C:\Program Files (x86)\Canon\EOS Utility\EOS Utility\EOS Utility.exe Chemin d’accès du module défaillant: C:\Program Files (x86)\Canon\EOS Utility\EOS Utility\EDSDK.dll ID de rapport : 69e33fcd-cbcb-11e2-beb2-001bfcc9f802 Nom complet du package défaillant : ID de l’application relative au package défaillant :
I'm using Windows 8 64bits and EOS Uility 2.13.0.0
I tried older versions - 2.7.0.3 and 2.9.0.0 - but still got the same problem 😞
Using the same computer everything was working fine with Windows 7 64bits and EOS Uility 2.7.0.3
Did anyone find a solution ?
Remark : don't know if it is useful but I start my installations using the original EOS cd (containing EOS Uility1.1.0.8)
07-01-2013 12:06 PM
My EOS Utility was working fine for a few years, 5D Mk2 on Windows 7 64-bit. I'd usually have to power the camera on and off to get the Utility to start downloading. But it stopped working. I just downloaded the newest update, nothing.
Any advice?
