12-16-2018 03:27 AM - edited 12-16-2018 03:33 AM
Hi folks,
Our firm has just upgraded our AV machine to an AMD Threadripper 2 2950X/Gigabyte X399 from an older Intel 5960X/Asus x99. Huge (and greatly appreciated) speed boost in everything we do, but can no longer connect a 5D Mk IV via USB connection. Software environment is a fresh install of Win10 Pro x64, v1809.
Attempted troubleshooting steps:
This problem appears localised to the new Ryzen-based production environment, as the EOS3 utility and camera are able to sucessfully connect via USB on the older Haswell-E Intel machine and, as a test, on a new-out-of-box Surface Pro 4.
Any further suggestions or troubleshooting steps to attempt would be greatly appreciated, as we shoot purely in large-format RAW and so the file transfer times via wifi are cripplingly slow and seriously frustrating.
05-05-2021 06:06 PM
@SoulsCollective wrote:Further update received from AMD:
Sorry for not getting back sooner.
Unfortunately, we have not received any updates from Canon even after several requests by our Dev team.
Would you happen to have a contact at Canon that could help facilitate this engagement?
This is unfortunate - according to AMD, they have been trying to get a response from Canon to help them implement a fix for this issue since February, and are yet to receive any update. As such, it appears that the problem is now understood but the ball is in Canon's court to get a solution.
Is there anyone on these forums that is able to assist with getting some attention from Canon to this?
Since February? February of what year? This has been an ongoing issue for a few years. The latest boards released by AMD in 2021 seem to have cured the problem.
05-05-2021 06:09 PM
05-07-2021 06:49 PM
05-08-2021 08:31 AM - edited 05-08-2021 03:22 PM
Same for my computer. New MSI motherboard with x570 chipset and latest BIOS. All other USB related problems are solved with this BIOS update (disconnecting external disks etc) but not for the EOS 5D. Still not connecting.
Strange thing is that connecting the camera to an USB3 port (C-type small connector on the motherboard) connect without problems. Connection on USB 3 with an A type connector fails.
I today checked the USB speed. Due to the adapter cable used the sheed is not super speed but high speed. In fact it is when connected via this adapter cable a USB 2 ports instead of USB 3. So still not able to use the max transfer speed of the camera with my brandnew PC
05-08-2021 02:25 PM
@peterVC wrote:
I just updated the bios of my Aorus x570 ultra to F33i which should be dealing with known USB issues, but the problem remains exactly the same as before. Really frustrating that a 4K camera and a 3K PC are simply unable to even transfer an image to one another. Was that a 1000$ extra option for each of the devices?
The firmware update didn't fix it probably because the AMD chipset seems to have a hardware related issue when it comes to their USB ports. This has been an ongoing problem for a number of years. It should not take years to update firmware to fix any type of firmware related issue, and it doesn't.
05-09-2021 12:50 PM
My RAID never shows up after sleep mode either. Has been an ongoing issue as well since I have the PC. I always need to reboot or start up to see my twin 6TB HDD's with photo and video archive.
05-09-2021 02:13 PM
@peterVC wrote:My RAID never shows up after sleep mode either. Has been an ongoing issue as well since I have the PC. I always need to reboot or start up to see my twin 6TB HDD's with photo and video archive.
The AMD x570 chipset is not the most recent generation of AMD chipsets.. Relatively speaking it is an "old chipset", one that probably surfers front he same hardware issue associated with a couple of generations of AMD products.
Please don't quote me on this, but I believe that the most recent generation of AMD motherboards is the AMD Ryzen 5 5600X CPU and chipset, which a couple of forum users have reported no USB issues. Here is a link to a review.
https://www.pcmag.com/reviews/amd-ryzen-5-5600x
05-20-2021 09:12 AM
After trying everything, finally got it to download from my Canon 5DIV using my USB 2.0 port on the PC. I am using an AMD Ryzen Threadripper PRO 3945WX Processor. I did not in this case use the Canon software.
05-20-2021 09:45 AM
The problem is related to the AMD USB-3 high speed buss, so connecting to a USB-2 port or using a hub seems to work.
06-18-2021 06:50 AM
OK, that seems to work, stupid I never even tried the USB 2 ports on the back of the PC. Lightroom and canon software are even processing and downloading my RAWS faster on my AMD usb 2 than on my surface pro 4 (5 yrs old) USB 3.0 port :s
