12-16-2018 03:27 AM - edited 12-16-2018 03:33 AM
Hi folks,
Our firm has just upgraded our AV machine to an AMD Threadripper 2 2950X/Gigabyte X399 from an older Intel 5960X/Asus x99. Huge (and greatly appreciated) speed boost in everything we do, but can no longer connect a 5D Mk IV via USB connection. Software environment is a fresh install of Win10 Pro x64, v1809.
Attempted troubleshooting steps:
This problem appears localised to the new Ryzen-based production environment, as the EOS3 utility and camera are able to sucessfully connect via USB on the older Haswell-E Intel machine and, as a test, on a new-out-of-box Surface Pro 4.
Any further suggestions or troubleshooting steps to attempt would be greatly appreciated, as we shoot purely in large-format RAW and so the file transfer times via wifi are cripplingly slow and seriously frustrating.
08-27-2021 09:20 AM
Firmware update 1.3.3 solved the USB 3 problem with AMD Ryzen processor. Today I upgraded my camera and connecting to USB 3 works flawless
02-04-2021 10:12 AM
@DaveSpittle wrote:Thanks for this. I literally received my new Ryzen 7 laptop this morning and I have been pulling my hair out trying to figure this out. I've been on to Canon but they don't know either. I'll have to keep checking back for update.
Thanks for doing the digging for us all
I think they were being polite. The hardware prerequisites for most of the Canon apps call for an Intel chipset. AMD is not officially supported.
02-04-2021 08:15 PM
That is not correct - neither the 5D Mark IV itself nor the specifications for EOS Utilities or other essential software lists an Intel chipset as a 'hardware prerequisite'. Instead, the only minimum requirements listed for the camera itself are "Windows 7 (excl. Starter Edition) Windows 8 and Windows 10OS X v10.7-10.11", while the hardware requirements for the EOS Utility are given as "CPU: Intel Pentium 1.6GHz or faster; RAM: 1GB or greater/2GB or greater (Windows 10 64-bit / Windows 8.1 64-bit / Windows 7 64-bit)".
These hardware requirments are satisfied by every CPU produced by either manufacturer since the Northwood series of Pentium 4 released in 2002. At no point is chipset compatibliity mentioned.
02-04-2021 11:59 PM
@SoulsCollective wrote:That is not correct - neither the 5D Mark IV itself nor the specifications for EOS Utilities or other essential software lists an Intel chipset as a 'hardware prerequisite'. Instead, the only minimum requirements listed for the camera itself are "Windows 7 (excl. Starter Edition) Windows 8 and Windows 10OS X v10.7-10.11", while the hardware requirements for the EOS Utility are given as "CPU: Intel Pentium 1.6GHz or faster; RAM: 1GB or greater/2GB or greater (Windows 10 64-bit / Windows 8.1 64-bit / Windows 7 64-bit)".
"Intel Pentium". Seems pretty clear to me. Are you even runnning Windows 7/8? Of course, not.
02-05-2021 12:09 AM - edited 02-05-2021 12:29 AM
"...or faster."
I don't mean to be argumentative, but there's a substantial difference between a hardware requirement of "your CPU must be more powerful than a 2002-vintage Pentium 4" and "Canon software will not run on a non-Intel chipset". Chipset =/ CPU. Outside of the very niche case of AVX512 extensions, there is nothing to distinguish software running on an Intel implementation of the x86 ISA and an AMD chip.
For starters, EOS Utility and related software runs perfectly fine on the non-Intel Apple hardware, and cameras other than the 5D Mark IV also function perfectly fine.
As per the first post in this thread, I (and the others posting here) are running WIndows 10, yes 🙂
02-09-2021 02:35 PM
Hello everyone, I wanted to confirm that this flaw in Canon's software (or quirky USB controller) prevents me from using the EOS Webcam Utility on my brand new Lenovo Legion 5 laptop (AMD Ryzen 7 4800H, RTX 2060) with my 5D mk IV. You have no idea how many hours I've spent troubleshooting this, reinstalling drivers, buying new USB cables, etc. Thanks to those who are pushing this forward with AMD and Canon. I was going to build a new Ryzen desktop to replace my 10+ yearold Intel i7-920 dekstop but this has given me pause because I work remotely and have many zoom calls throughout the day. I hope AMD, or AMD + Canon can develop a fix, but I'm pretty disappointed that this has already been going on for 4 months and Canon still hasn't formally acknowledged the bug. It's disappointing when a company we have invested so heavily in fails to be honest and do the right thing by its most loyal customers.
04-30-2021 10:58 AM - edited 04-30-2021 10:59 AM
I found the following:
PC MSI motherboard with Ryzen 3900X and X570 chipset.
USB2 USB 3 type A and type C connectors
Connecting the 5D mark iv on a USB 2 port does wordt without problems.
Connecting an EOS 7D on a USB 2 and USB 3 port works fine.
Connecting a 5D mark 4 on a USB 3 does not work.
However, using a USB 2 cable in a USB 3 port works fine.
Also connecting the 5D mark 5 to a USB 3 C type connector works ok. (cable with A to C adapter)
04-30-2021 01:46 PM - edited 04-30-2021 01:50 PM
@SoulsCollective wrote:"...or faster."
I agree. The CPU is not the problem. The problem is the AMD Chipset. There is an issue with the USB ports, not the CPU
02-05-2021 04:08 AM
I'm not being funny but we are in 2021!!.. AMD have been going for years, the Ryzen chips are the equivelent of the Intel chips nowadays so I would have bet my life on the Canon Utilty VERSION 3 would not have a problem running on the latest of pc's.
I could understand if we were on version 1 or maybe even version 2 but come on.. Canon need to get with the times
05-20-2021 09:12 AM
After trying everything, finally got it to download from my Canon 5DIV using my USB 2.0 port on the PC. I am using an AMD Ryzen Threadripper PRO 3945WX Processor. I did not in this case use the Canon software.
05-20-2021 09:45 AM
The problem is related to the AMD USB-3 high speed buss, so connecting to a USB-2 port or using a hub seems to work.
