02-10-2023 05:35 PM - edited 02-11-2023 01:56 PM
Windows 10, fully updated as of 2/10/23.
I borrowed some text from another thread but it describes the problem in detail..
"It flat out refuses to install. I go through all the install process, it unpacks, goes through install progress bar comes close to complete, it hangs for several minutes and then pops up with
EOS Webcam Utility
! Service EWCService' (EWCService.EXE) failed to start. Verify
That you have sufficient privileges to start system services.
Retry/Cancel
Try retry all day long and it just repeats only option is to cancel" .......which uninstalls the package.
I am administrator and right clicking and running the install as an administrator does nothing.
I have rebooted, updated the machine to the latest version available and installed GPEDIT.MSC and set privileges in it according to a web article. Still does this and it will not install.
The log that is generated is useless. The developer created an exception routine but didn't put anything in the log to say why the exception occurred.
04-07-2023 05:45 AM - edited 04-07-2023 05:51 AM
I’m just the messenger. I apologize for explaining why it will never work with an upgraded Win10 OS from Windows 7, 8, or 8.1.
08-11-2023 12:06 AM
Hey there Jeremy, I sure do hope you are able to help me out especially since you have worked at windows support my Laptop is currently running widows 11 and we have been trying to download the webcam utility pro app for about the past 7 hours and we keep getting the EWCServie.exe failed to start. verify that you have sufficient privileges to start system services.. I've looked around quite a bit to see what fixes have worked for other people and I've even tried downloading the 1.1 but that has not worked either . Can someone please help us with this..
02-19-2023 02:36 AM
I have been having the same problem. I have been able to download other stuff. I specifically bought my camera for using this feature. I made sure my brand new computer has all the specks it asks for. I am getting really frustrated and trying to find different off brand program to download that will work instead.
02-19-2023 07:02 AM - edited 02-19-2023 10:27 AM
There is some nuance that the install process is missing. I actually ran the install until the error message popped up and then went into services and EWCService was actually installed, and started, (with Automatic setting) so this is a false error message. Something else is going on. I confirmed this by running the EWC Utility, since the shortcut remains until you cancel the install, and was able to see it as a camera option in Windows camera. However it would not feed video....I suspect the install is not entirely done. I powered down the machine using the long press on the power button (to exit without the uninstall process running).. When I restarted the laptop the service was still installed. The EWC still showed as a camera option but it would not feed video....again it was an incomplete install. I am at a loss as to get it working. It should. I am still pondering but may not have any more avenues to pursue.
BTW, thanks for posting. This confirms to me that it isn't an "old" machine issue since my laptop also meets the minimums as stated by Canon. Can I ask what machine and operating system you are having problems on? And, does your new machine have a built in camera?
03-16-2023 02:23 PM
I have the same error. I have an old motherboard with a q9550 processor, 1050ti graphics card and 8gb of ram. Could this be a problem? Or is the problem because I'm from Russia?))) I hope it's not so 🙂 Tomorrow I'll try to install the software on another computer, I hope the situation will change. I wish you all the best! 🙂
03-20-2023 12:10 AM
Smh this is crazy I been trying since 12 noon and still nothing, brand new laptop :.. did u figure it out ? And ifso plz let me know …. Windows 11
03-20-2023 10:43 AM
No luck so far. Haven't done much more. One of my posts in this thread explains that I believe the error is a bogus message since I could see that the EWCservice.exe had actually installed and started. Too much else to do rather than chasing this....
04-06-2023 05:16 PM - edited 04-06-2023 05:17 PM
I appreciate your diligence in reporting and following up on this problem. I've encountered the same error—though, in my case, the error message was a correct report; i.e., the service had not, in fact, started successfully. Since it sounds like the error message was incorrect report for you, I've created a new thread for my scenario. As they're so closely related, however, I wanted to make you (and anyone else with this error) aware of that thread as well. In the meanwhile, I hope you've had more luck than me in getting this resolved.
04-06-2023 11:40 PM - edited 04-07-2023 10:40 AM
Try the following.
When the error dialog pops up...
Windows+R key
Enter "services.msc" in the run dialog, press ok
Scroll to service EWCService. Right-click on it and select properties. Change start up type to disabled. Now select stop service. Once the service stops, press the re-try button on the error dialog. The install should complete. Change the service start back to Automatic, save. Restart the machine and test.
I have not tested this myself.
**Edit, there is a difference between the v1 and v2.0 versions of the software. (Device driver vs. application) v1 did not work when the EOS Utility was active. I'd exit this app from the system tray (temporarily) while I tested v2.0.
~CarePaks Are Worth It
04-07-2023 09:57 AM
Thanks for the suggestion. It will be later today but I will give it a shot.
