10-02-2023 12:04 AM
Hello, I have a problem with EOS Webcam Utility on my PC. It only displays the EOS Webcam Utility logo. I have tried reinstalling it multiple times, but it still remains like that. The operating system I'm using is Windows 10. Is there anyone who can help me because it works on other devices when I try it?
10-02-2023 05:30 AM - edited 10-02-2023 07:49 PM
Do not use a USB port expander. There are known issues associated with USB ports on many of the AMD motherboards. Make sure that your motherboard has the latest firmware. If you built your PC platform yourself, then I will not be able to assist you any further.
10-02-2023 05:57 AM
I don't use an extended USB port, and I'm using an Asrock motherboard with an Intel i5 processor. The motherboard firmware is also up to date.
10-02-2023 11:55 AM
Make sure that the EOS Utility is not running when using the EOS Webcam Utility. Check the taskbar to see if it is running, and close it. What camera are you using and how are you connecting to the computer (Wi-Fi or USB cable)?
10-02-2023 02:22 PM
Canon 1200D and i'm connect to my computer use the USB Cable.
10-02-2023 02:26 PM
You need to make sure you have the most current version of the software installed. Learn more at canon.us/livestream
10-02-2023 06:06 PM - edited 10-02-2023 06:30 PM
Make sure that Wi-Fi is disabled in the camera in order to use the USB cable.
Google Drive or One Drive will often interfere with EOS Webcam Utility.
09/26/2023: New firmware updates are available.
CN-E45-135mm T 2.4 L F - Version 1.4.0
EOS 1DX Mark III - Version 1.8.0
EOS R6 Mark II - Version 1.2.0
08/18/2023: Canon EOS R5 C training series is released.
