EOS Utility installation issues for my r5 on my MacBook Pro M1 Max
KirkEdwards
Trying to initiate a tethered capture in Lightroom Classic from my r5 and am having zero luck. Tried to download the latest version of EOS Utility but it will not install, just says transferring files for a second and then craps out every time. Extremely frustrating.
2 REPLIES 2
Nick2020
Hi KirkEdwards,
I'm not sure where you tried to get EOS Utility, so let me walk you through the steps.
You can download the software from our website. Let's start by going to
http://www.usa.canon.com/support
Enter your camera model in the prompt, select it from the options that load under the box, and then press ENTER.
The EOS Utility download is actually a zipped file. When it finishes downloading, you'll want to double click the file. This will create another file with a drive icon on your desktop or in the same location as the downloaded file. Double click that and you should see the installer screen. Follow the on-screen prompts, and EOS Utility should install.
KirkEdwards ,
The installer is a self-extracting zip.  Are you having a problem with extracting the files or running the .dmg installer?
If you're not seeing the folder with the executable on your desktop', its possible you don't have the hard disks option checked on you Mac.  Without this enabled in properties, the unpacked folder won't display on your desktop.
