EOS Utility crashes Windows firewall
ShadowHowler
Hello.
I bought a 70D a few days ago and wanted to try the wi-fi function today.
I downloaded and installed the latest software for my camera from the Canon support site.
Im having the following problem with the software.
When i run EOS Utility I get the following message:
-To connect to the camera via LAN, some Windows Firewall settings must be changed. Do you want to make these changes?
I click yes and get the next message:
-WFT FirewallSettings has stopped working.
The next message i get after i click on close program says:
Could not change the Windows Firewall settings.
I tried adding the EOS utility and EOS utility 2 manualy, and allowed acces, but it still doesnt work.
12 REPLIES 12
That worked for me, thank's a lot!
Regards from Mexico
THANK YOU SO MUCH! IT WORKED AFTER TRYING TO ADD IT MANUALLY TO THE FIREWALL!!!
God you're an angel THANK YOU SO MUCH
