EOS Utility 3 all options grayed out, says camera isn't connected
dan329
Using a EOS 5D Mark IV camera using a wifi connection
Running OS 13.6.1 Operating System
Running 3.17.2 EOS Utility
When turning the camera on, the EOS Utility software fires up like it's supposed too automatically.   The computer recognizes that the camera has been turned on.   But when the software starts, all options are grayed out and the software tells me that I must connect a camera to the utility before I can do anything.
I have tried deleting all settings and setting up the camera settings from scratch, this sometimes will allow it to connect, once and then never again.
I have deleted all canon software and reinstalled, this made no difference.
Canon suggested that I try reverting system software to an older software, but this is not an option.   Ventura has been out for over a year, any issue should be resolved by now.
I have spoke with Canon and they were able to reproduce the issue on their end 2 months ago, but so far have done nothing to correct the issue.
Has anyone ran into issue and found a work around that will consistently work?
9 REPLIES 9
Pilgrim76
right the same issue for MacOS 12.7.1 (Monterey).
I tried to fix in the very same way, tried to use previous versions of EOS Utility – no result.
cable connection works fine.
jrhoffman75
Many folks have been having issues with EOSU and later macOS versions. This is the first report I have seen with a problem with WiFi.
dkallan
Same problem, only when using Wifi.  EOS Utility 3 automatically launches as soon as camera connects to Wifi, but everything stays greyed out.
Which model camera.
EOS R5, firmware 1.9.0
Does it work with cable connect?
Waddizzle
The 5D4 does not even have Wi-Fi.
It does.
Ah, that’s correct.  It lacks Bluetooth, which can automate Wi-Fi connections and configurations.  My 5Dsr does not have it.
Make sure the camera is set for USB.  It cannot switch between USB and wireless on its own.
