08-06-2024 11:11 AM
Even a freshly downloaded copy of the latest EOS Utility (EU-Installset-M3.18.5.13.dmg) crashes shortly after launch. The install fails. The summary crash report generated by Mac OS 14.6 follows. My comments and questions are after the end of the summary.
08-06-2024 11:21 AM
Hi, Jim.
Which camera are you using?
Where did you get your copy of the EOS Utility?
08-06-2024 11:40 AM
Canon R5.
From the CanonUSA site. https://www.usa.canon.com/support/p/eos-r5#idReference%3Dsoftware-drivers
Thanks.
Jim DeWitt
Frozen Feather Images
08-06-2024 11:47 AM
Good.
I'm not tech support, but I nerd out on a lot of stuff, and I'm a Mac user. I've found that some software is weird if you don't install it from the desktop instead of the downloads folder. If you haven't already, eject/trash the current installation DMG.
Try dragging the downloaded file to your desktop and then double-click it so that the DMG mounts from there. Once you've done that, you'll see the mounted disk icon on your desktop. Try running the installer now, and see if you have better luck.
Let me know how it goes!
08-06-2024 12:01 PM
I saw that suggestion in another thread and tried it. Same result, right down to the same bad call in the Apple crash report.
Jim DeWitt
08-06-2024 12:09 PM
Try downloading a fresh copy. Erase your current copy.
08-06-2024 12:17 PM
Thanks for the suggestions. I deleted all earlier downloads, emptied the Trash, downloaded a fresh copy to the Downloads folder, dragged the .dmg file to the Desktop. Mounted the .dmg file, dragged the eum3.18.5-installer icon to the desktop and launched. Same result: crashed about a quarter of the way through based on the progress indicator bar.
Jim DeWitt
08-06-2024 01:05 PM
If you have a third-party security program like an antivirus or malware protection, it might be interfering by being a little too aggressive, so you can try temporarily disabling it. (Think Sophos, Mcaffee, Bitdefender, etc.)
Analyzing your crash report indicates that (in plain language) there is something where nothing should be.
A handful of things could be causing this, including the app being denied access (by security software, as I mentioned above) or by not being given admin/elevated privileges. You should be asked to enter your password/TouchID when you install it to allow the app access to all the folders it needs.
If your user is an admin, and you've given the app permission to install, and you've disabled any security software, and it's still not working, I think calling support for one-on-one guidance would be super helpful so they can review everything with you. They're at 800-OK-CANON (800-652-2666), Monday through Friday.
08-06-2024 01:18 PM
Stephen, I appreciate you time. I'm logged into the Mac as an Admin user. Other software installers work just fine so I don't think it is likely to be a question of privileges. The only security program I run is MalwareBytes Premium, which is pretty passive, but just in case I turned it off and tried again, with the same result. Notably, I don't get a password dialog before it crashes.
I guess some time with Tech Support is next. Thanks for the suggestions. I'll report here the outcome of the tech support process.
Jim DeWitt
08-06-2024 04:36 PM
Maybe use an uninstall app to clean out all traces of the software before reinstalling.
