04-18-2020 12:41 PM
I downloaded the EOS utli sofware, connected my canon 70 to macbook via usb cable. When I start the EOS util 2, the camera setting/remote shooting is disabled.
I made sure that the wifi is turned off.
This feature is always greyed out in both video and camera mode.
How can I get this to work?
04-18-2020 01:45 PM
@khalidhajsaleh wrote:I downloaded the EOS utli sofware, connected my canon 70 to macbook via usb cable. When I start the EOS util 2, the camera setting/remote shooting is disabled.
The camera is not being recognized by the computer. Make sure you are using a USB data cable, not a USB charging cable.
04-18-2020 02:01 PM
04-18-2020 07:28 PM
But when I plug-in my camera to the cable, the EOS util starts on its own. I searched on amazing for mini usb to usb data cable but all the results show charging cables. How can I find a data cable?
That doesn't sound as though it's a cable (data vs charging) issue.
The 70D is a fairly recent camera. Are you sure it doesn't require EOSU 3?
04-18-2020 08:05 PM
But when I plug-in my camera to the cable, the EOS util starts on its own. I searched on amazing for mini usb to usb data cable but all the results show charging cables. How can I find a data cable?That doesn't sound as though it's a cable (data vs charging) issue.
Good question. The 70D Product Support page appears to show MAC OS-X Snow Leopard 10.6 running EOS 2 as part of the EOS Utility CD. The latest downloads for Mac OS Catalina show EOS 3.12.
04-18-2020 08:35 PM
04-19-2020 03:12 PM
When I tried the EOS3, I get a messageb that your device is not recognized.
Are you deleting the software prior to installing a new version?
Which version of EOSU 3 did you install? You may need to work your way through the upgrade path.
To install EOSU 3, I might try starting at OS X Mountain Lion. That seems to be when a transition might have been made from EOSU 2 to EOSU 3. I have no idea why they transitioned, but it seems to coincide with a change from OS X to MacOS.
04-19-2020 05:40 PM
it is sort of interesting because I just downloaded the EOS software yesterday from Canon's site. It installed both EOS 2 and 3. By default, when I plugin my 70D it opens EOS 2. I will remove EOS 2 and see if that fixes the problem.
04-19-2020 11:30 PM
@khalidhajsaleh wrote:it is sort of interesting because I just downloaded the EOS software yesterday from Canon's site. It installed both EOS 2 and 3. By default, when I plugin my 70D it opens EOS 2. I will remove EOS 2 and see if that fixes the problem.
You hare not answering any questions. This makes it difficult to assist you. Deleting the applications means deleing ALL of it, not just some it. On that note, I suggest that you contact Canon Support.
