02-18-2025
05:59 PM
09:24 AM
I just started using RAW mode (actually J+R mode) on my recent vacation and am now using DPP4 to edit the RAW files to create pictures I can print & frame. So I have a full size (not cropped) image and I save it as a jpg and my PC reports that it has a resolution of 6240x4160. Doesn't seem to matter if I save them in DPP with a different output resolution. Does that say than the best I can do for a raw image from my I EOS R is ~20x13" (on a 300 dpi printer)? Looking for a better understanding the best way to post process the images from my camera as well as a general rule or formula in order to determine the size I can reasonably print a photo. TIA
02-18-2025 06:41 PM
You can also use a program - I don't know if DPP can do it - to up res a bit.
02-18-2025 06:06 PM
How close are you going to view the image? For large formats, 150 dpi is generally OK because you view them from several feet away.
02-18-2025 06:30 PM
Thanks kv! Good advice. Since these would be at a distance I can reasonably expect to stretch a bit as long as I don’t over do it
02-18-2025 06:41 PM
02-18-2025 07:21 PM
Canon has this tool:
Neural network Image Processing Tool
02-18-2025 07:34 PM
Thanks, I saw that after paging through the DPP manual but in my case I wasn't that interested in the noise reduction feature. True it can do 2x but per kvbarkley I can stretch the image a few more inches and should still have a reasonable picture to hang on the wall
