Digital Photo Professional 4 Save and Convert Multiplying Windows Issue
AndrewMarescha
Hello,
My issue is this:
I go into Digital Photo Professional 4, click on a single raw photo, go to "save" button over he image, I click it, then the window showing the progress via a bar, but then about 9 other windows that are the same pop up. I don't want this. Why is it doing this? How do I stop it from doing this?
-Andrew Mareschal
12 REPLIES 12
@wq9nsc wrote:
Click the close dialog box when finished in that window.  Otherwise it leaves the window open when it finishes converting and you end up with all of those windows.
Rodger
Exactly! And when you switch to a different image to edit, it hides that progress window from the main screen leaving the only evidence it is still open in the taskbar. Good catch.
FD
DId that. It did not fix the problem.
Click on the "close dialog when finished" box and it does it for you.
