05-04-2023 06:04 PM
What EOS Utility do we need for 5DmkII and Catalina?
Downloading EU-Installset-M2.14.31.12c.dmg from the 5DII support page on Canon doesnt work.
The app does nothing when the 5DII is connected to the Mac using USB.
Running the latest EOSU3 (EU-Installset-M3.16.11.1.dmg) detects the USB but tells us to install EOSU2.
What do we do?
05-06-2023 08:35 AM
Hi there,
The EOS 5D Mark II used EOS Utility 2, it would not be compatible with EOS Utility 3. However, EOS UTility 2 is not compatible with 64-bit Mac operating systems, that would be OS X 15 and later. You would be able to use the Mac application Image Capture to import images via USB instead, it will already be installed in your operating system.
05-06-2023 09:38 AM
Gold333:
If you downgrade to Mojave, not that big of a difference, you can run EOS2. But, as Mark35mmF2 said, Image capture can download the images just fine.
05-08-2023 01:06 AM
Thank you but OSX 15 does not exist.
The current OSX (MacOS) is version 13.0 Ventura. I am using version 10.15 Catalina.
I do not need to download images I need to control my camera from the computer in tethered shooting using Eos Utility.
Some people have stated that some version of EOS Utility 2 work on MacOS Catalina, I can’t find that version
05-09-2023 10:16 PM - edited 05-09-2023 10:18 PM
Thank you for taking the time to offer advice.
I can't downgrade to Mojave as my workflow contains the last version of all apps that run on Catalina (FCP, PS, etc).
I also do not need to download images from the camera after shooting. I am looking for a tethered shooting solution. If Canon has no solution for this 5D Mark II what 3rd party app would you recommend for tethered shooting.
I already use a wifi card and Shuttersnitch for wireless transfers of small JPGs, but I am unhappy with the 3s per image transfer speed. This is why I am looking for a -tethered shooting- solution.
