03-27-2023 04:05 PM
Just downloaded DPP4. Running on a Windows 10 PC. When attempting to convert CR3 images to JPG, DPP processes to 5%, then closes the process window with no output. DPP4 does not crash, but no output files are saved. I rebooted the PC and ran DPP4 with all other apps closed. Same result. Is this a glitch or a setting I've overlooked?
03-27-2023 04:44 PM
Please try saving the files to another folder. Not the one your originals are in.
Let us know if this helps?
03-27-2023 06:16 PM
Thanks Rick. I'm already working out of a different folder that I created to test the conversion. It will not work on this Windows 10 PC. However, I downloaded the app on a laptop running Windows 11 and it works fine there.
03-27-2023 06:33 PM
@traingazer wrote:Just downloaded DPP4. Running on a Windows 10 PC. When attempting to convert CR3 images to JPG, DPP processes to 5%, then closes the process window with no output. DPP4 does not crash, but no output files are saved. I rebooted the PC and ran DPP4 with all other apps closed. Same result. Is this a glitch or a setting I've overlooked?
Works for me with W10. Saving to same folder. Not selecting any special settings.
