12-11-2017 06:43 AM
12-14-2017 10:12 PM
06-14-2020 12:21 PM
Your suggestion of using Alt+J helped. Thanks a lot.
09-07-2020 08:02 PM
FWIW, I have the same situation. G5x. Cannot view AF points in DPP.
Pretty lame of Canon not to support power shots.
09-08-2020 06:13 AM
@ejohansen wrote:FWIW, I have the same situation. G5x. Cannot view AF points in DPP.
Lame? No, it isn't. How many AF points does your camera have? It has the same number as most PowerShots. One!
09-08-2020 12:00 PM
You can move the AF point.
09-08-2020 12:24 PM
@ejohansen wrote:You can move the AF point.
"Cannot view AF points in DPP."
Good, we're on the same page now. One AF point, not multiple AF poinnts. It is what it is. I doubt if it will change.
07-05-2024 01:18 PM
7 years later....
Same problem. Was searching for a solution to the same issue and came across this thread. Must be a HUGE problem if it's 7 years later and Canon still can't figure out how to fix it and make it easy to use...
07-05-2024 02:37 PM
As I noted earlier, if the AF system isn’t active and locked when the shutter is fired, then DPP will not display a locked AF point.
Your cameras should behave the same way.
07-05-2024 03:15 PM
Thanks for the reply. Actually, AF was active and it originally showed these points when I opened in DPP, but had a huge "info" panel obscuring 1/4 of the screen In trying to get rid of that screen suddenly the focus points now won't come back. I tried the advice given earlier in this thread after searching for "how to", but the indicated button to select for showing the focus points (which was helpful info here!) won't work.
DPP has always been a clunky, non-intuitive piece of kluged-together software and for that reason I've always used other software - mainly GraphicConverter, which does everything DPP can do - and much more (like always show the focus point, regardless of manual or auto-focus - ) and works well and intuitively. Then of course Photoshop for post-processing. I was just trying to see what DPP might show for a particular situation (kinda as a double-check) but have already spent way too much time trying to figure out this archaic clunky software. It just reminds me why I don't use it and why there isn't any good reason to waste my time further. I do appreciate your time to respond. Thanks!
