04-14-2020 10:45 AM
Hi I have 2 sx530HS and both were setup with Image Gateway and all was working fine no problems until the shutdown of the server. Today I tried to connect them to the new Image.Canon server and every time I try the update cloud button on the cameras as decribed in the setup from image.canon I get "Set the correct date and time" on both cameras. The correct date, time and time zone is correct on the camera. I've searched through several posts on here from others having similar issues in the past saying you need to change the camera name to something else before trying to connect, or completely reset the wireless settings like it was a brand new camera. None of that worked. I logged into the new image.canon and deleted one of the cameras that I guess was transfered over from image gateway and that had no effect. Am I missing something or is the service not fully up and running. Any help would be great as our company uses these for shipping picture verifcation and manually transfering images takes a ton of time and is the only reason we bought these cameras is so we could transfer pictures automatically.
Thanks.
03-25-2021 03:38 PM
@RebelxButterfly wrote:
Im having the same issue. Has anyone found a way to fix this problem? Canons are normally great cameras but not being able to use wifi when it states WIFI right on the camera is very disappointing. If this problem isnt fixed, i promise this will be the last canon i buy. Im not going to spend hundreds of dollars for false advertisement.
The way I personally found to fix this issue was to buy a FujiFilm. Truth is, they likely did this intentially, so there will never be a fix from Canon. I will never buy another Canon product again, and I am replacing 3 Canon cameras, 2 Canon scanners, and 1 Canon printer.
03-29-2021 02:57 PM
03-29-2021 04:11 PM
I feel the same bout buying different products. I got my powershot a year ago to add to my collection but feel its not the greatest Canon i have. But theres no reason why to buy canons from now on if their not willing to fix their own mistakes that they made. I emailed Canon and they said they do not have a online support and that i have to call. I dont have time to be on the phone for an hour or so. And like you said, it doesnt look like this problem is going to be fixed anytime soon... Sad 😢
Besides your time and effort, Canon charges money for that phone call... regardless of outcome.
03-29-2021 08:54 PM
04-25-2023 01:02 PM
I have the same problem, for one thing there is no SX 700 HS on the list, no further firmware updates. I tried to connect my camera to the new Image.Canon server and every time I try the update cloud button on the cameras as decribed in the setup from image.canon I get "Set the correct date and time" on both cameras. The correct date, time and time zone is correct on the camera.
04-25-2023 01:12 PM
Yep, they don't give a dang. They just want you to buy a new camera so they can screw you again in a few years. Buying a FujiFilm solved my issue.
04-25-2023 02:54 PM
This seems to be a old thread but like the SX530HS my SX700HS has been showing the same-to recap:
Please tell me there is a solution, I have been saving my stuff in other ways but this would be a much more convenient way.
Thanks in advance.
My camera is otherwise still brilliant. l had gone to curry's to buy a different one!. 🙂
