Connect with Canon Camera Connect without WiFi
ddt
Using a 90D
I am unable to get a usable connection with the Canon Camera Connect app.  I'm in an area with poor Wi-Fi and going to a place with no Wi-Fi.
I connect my camera to the app but when I try to either download pictures or use the app to remote control the camera it says it's shifting to Wi-Fi for better connection (better than what? Bluetooth?).  It fails every time.  Again Wi-Fi is not good here.  I'm certain Bluetooth is better.
Have tried disabling Wi-Fi connection on the camera to force a Bluetooth connection.  Every time it says I have to enable Wi-Fi to proceed.  I do and it falls.  I tried turning on off Wi-Fi on my phone.  The same thing happens.
I've been able to manage a strong enough Wi-Fi connection to make this post.  But I'm going to a place where even that won't be an option.  I need to be able to use the remote function.  Can somebody please help me connect my phone to my camera WITHOUT WiFi!
Thanks
12 REPLIES 12
I've covered this behavior before.  The Wi-Fi menus have changed between various hardware releases.  There is an old standard and new standard.
Older wireless standard icon
 (called wireless settings)
New wireless standard icon
 (called communication settings)
How you interact with each depends on the model of the camera you own.
To be clear, you can connect your wi-fi capable phone or tablet to your camera using an adhoc connection.  You do not need a wireless network for both devices to connect to and can do so anywhere.  Middle of the ocean, on a deserted island, in space, etc. The camera is the hotspot and is the device broadcasting its own network.
Wireless is used for image transfers.  It is faster than bluetooth.  Bluetooth is used for GPS location tagging.
Its best to review your user manual to understand how to successfully configure and connect to your Camera.  When a external network is not present, you should confirm the camera's SSID broadcast name and password (if used) to ensure your mobile device will connect to the camera's broadcast.  Once I enable Wi-Fi on the camera, I open the connection settings on my mobile device, choose the camera's SSID and connect to its network.   Once this is initiated, the mobile device will prompt you to open the Canon Connect App to complete the connection.
This is where people often get hung up. iPhones are notorious for ignoring you telling them to connect to the camera and if you are within range of a known wireless network, like at your home, the connection will fail.  With iOS it will always attempt to connect to a wi-fi network that has an internet connection behind it.  Android OS does not have this issue but if you don't have the camera's SSID and broadcast configured prior to making the connection in Canon Connect, wireless pairing will also fail.  If your camera is using the new standard (Communications Settings), there is an Advanced options menu on the connection menu that allows you to switch between what the camera does.  1. look for a compatible wi-fi network that both it and a mobile device can connect to for pairing, or 2. configuring it as the host (no wifi networks of any kind) are used and the mobile device connects to the camera's SSID (ahoc) network.  Once set, and after a connection is made successfully, the camera will seamlessly pair (transitioning from bluetooth to wireless) moving forward.  My R5 C has the older standard.  The R50v has the new standard.  While I prefer the older one, I have since had to become intimate with the latter.  It's a bit more finicky.  I'm using it with a BR-E1 and phone.
Thanks Shodow,
I understand all that. The wifi is a direct connection between the phone and camera for faster data transfer. I have an RP for several years, and an R6 for a few months. Both were connecting just fine, image transfer, remote control, worked great. Suddenly, they don't anymore.
After one email response from Canon, I was able to connect to the R6m3. Once.
I found the password from the connect to EOS utility tab. Input it, and connected. But if I disconnect, the SSID and password for the camera changes. Which means every time I want to connect I have to jump through camera screens to find the password, then jump to my phones wifi settings and connect via password to that moments SSID before the session times out.
Like I said, it worked with out any of this a couple weeks ago. So I don't know if the SSID/password changed on the camera each time because I never looked at it. No new camera software has been installed. Not sure when the last time camera connect was updated.
“ Like I said, it worked with out any of this a couple weeks ago. So I don't know if the SSID/password changed on the camera each time because I never looked at it. No new camera software has been installed. Not sure when the last time camera connect was updated. “
Did the phone update itself?  I suggest deleting the existing connection setups in both the phone and the camera.
