12-10-2022
03:25 AM
09:03 AM
I installed EOS Utility 3.16.0 for Windows 11 however, when I try to connect my EOS 70D to my computer, either via usb or wifi, a message appears saying "Application not installed. Please install EOS Utility 2." In all the tutorial videos I've watched, EOS Utility 2 appears in the list of software to be installed, however this was not the case for me. Why might this be? Additionally, where would I be able to download EOS Utility 2? Long story short, I would like to view my photos on my monitor immediately after taking them. If you have any recommendations or advice it would be greatly appreciated.
12-10-2022 09:37 AM
Then download and install EOSU 3.13.20.
12-10-2022 05:52 AM - edited 12-10-2022 09:38 AM
In order to assist you, we need to know what OS (version and build) is your "computer" is running?
A search of downloads for the EOS 70D shows the following:
EOS Utility for windows: v3.15.20
EOS Utilty for MAC v3.16.0
You post is not clear. It says you installed v3.16 for windows? Then you ask where you can get the installation file from. Was the file you installed originally from Canon's website?
Downloads for the EOS 70D are available here:
Canon Support for EOS 70D | Canon U.S.A., Inc.
12-10-2022 05:58 AM
I downloaded v3.15.20 originally, but when I tried to run it, it said there was an update and updated to 3.16.0 I am running on windows 11 home
12-10-2022 06:04 AM
I downloaded off the canon website
12-10-2022 08:54 AM
EOSU 3.15.X should install EOSU3 and EOSU2.
Both V2 and V3 can exist together. Updating to a later EOSU3 shouldn't delete V2.
Check in the Canon Utilities folder; you should see EOSU2. Start EOSU2 directly rather starting the top-level EOSU app.
12-10-2022 09:34 AM
If you look at my original post, EOS Utility 2 was never downloaded. It wasn't on the list of software. How can I download EOSU2?
12-10-2022 09:37 AM
12-10-2022 09:47 AM
How? Where do I find this download?
12-10-2022 09:50 AM
Same place you found the other downloads. Just keep scrolling down.
12-10-2022 09:52 AM - edited 12-10-2022 10:02 AM
An older version would work as John pointed out. You should also be able to manually launch the EOS Utility 2 directly from the Canon Utility folder. After this is done once, it should work with the 70D which requires version 2 of the Utility, not 3. Both versions get installed with newer versions of the installer. Your system is trying to launch v3.
Close the EOS Utility program on your desktop. Now close v3 of the utility by right-clicking its icon in the system tray. Now launch v2 of the utility directly from the program folder. It will look similar to this. Select quit, then launch v2.
Now the correct version (v2) should be running waiting for the 70D to be connected. As you can see from the image, different options are available. The software can run on demand (meaning you have to start it manually each time you want to use it, or can be set to run automatically each time the system starts) You can pick the option that works best for you. Edit... yes older version works too, as those only include v2 of the utility.
